03-20-2019, 09:01 PM | #1 |
Rep 334
E90 M3 took 9.5L of oil and shows only half full?
Took the car to a local indie shop. Brought a turnermotorsport lquidmoly oil change kit that came with 9L of oil. When picking it up shop said they had to use all 9L plus half a liter but edipstick shows only half full. End of day got home from work and it still only shows half full.
Should I be concerned? |
03-20-2019, 09:37 PM | #4 |
Rep 2,747
I just put 9.5-9.75l in mine after sump was off.. if they sucked all the oil out of filter housing, and did a level car oil change and let it drip out 9.5l should be fine..
Any to clarify you mean the oil is saying "ok" with it half way on the full gauge, not that it's half full..
9ers
03-20-2019, 10:10 PM | #6 | |
Rep 950
03-21-2019, 03:34 AM | #8 |
mTekMods
2123
Rep 2,888
Last std oil service on my car took 9.5 also and it was on the half mark. Let the car go to sleep then recheck it.. when I drained My oil and changed my oil cooler it took nearly 11qts, the cooling passengeways and cooler lines hold a lot of oil.
03-21-2019, 06:02 AM | #9 |
Rep 334
Good to know thanks
03-21-2019, 12:28 PM | #14 | |
Rep 5,506
It can take days of driving to have the oil indicator reset - it's very slow. Keep hitting the refresh button every time you drive.
Auto Detailing Enthusiast!
03-21-2019, 04:47 PM | #15 |
Rep 334
03-21-2019, 05:02 PM | #16 |
Rep 1,389
That button does essentially nothing, the reason it takes long to read the oil level is because oil temps need to be at operating level before the oil sensor will even start doing it's thing... so it's the warm up process that takes long, not the sensor. Every morning when I get in the car, as soon as I hit just below normal temperature (about 10 mins or so on the way to the interstate) it starts calculating. On a warm start-up, it's less time, but again all about the temperature.
04-30-2019, 01:38 PM | #18 |
Rep 5,506
You can hold down the BC button on the stalk when you're on the oil level screen to refresh the reading once it shows a oil reading.
04-30-2019, 03:32 PM | #19 |
Stop the hate, get a V8
3850
Rep 8,625
Being a half-liter down in a sump of that size isn't going to cause problems.
Being a half-liter over-full will cause issues like foaming, excessive crankcase pressure, etc.
Past: 2011.5 M3 sedan ZCP |
04-30-2019, 11:00 PM | #20 |
Rep 1,792
my last two oil changes have taken roughly 9.5 qt each time, and I got the "ok" reading (full mark) both times, didn't have have to wait 24 hours to get an accurate level reading.
