11-19-2018, 02:20 PM | #1 |
Rep 57
piston surface
I have 150k miles, looked through the valve cover with a borascope to see inside. Didn't expect to see it so black. Is this normal on our cars with 150k miles? My oil consumption is around 3 quarts / 5000k.
11-19-2018, 05:57 PM | #3 |
Rep 4,155
Bimmer Barney1250.00 |
11-20-2018, 07:25 AM | #4 |
Rep 2,907
Drives: 2011 E93 M3
The tops of pistons don't stay shiny and new looking, especially in engines with such high mileage. Some carbon buildup is normal.
That's pretty excessive oil consumption and given the appearance of your piston crowns I'd say your rings are worn out. Your engine is tired. Keep running it and enjoy it as long as you can or rebuild it/replace it with a lower mile engine. |
IanMan384.00 M3ANMACHINE929.50 |
12-04-2018, 09:23 AM | #6 |
Rep 142
looks like a lot of pre-ignition has occurred in that engine. You get enough oil in the combustion process and it reduces the effect of the octane which can make it easier for pre-ignition.
-Kai
12-04-2018, 03:20 PM | #8 |
Rep 142
If it's above avg oil consumption it will either be rings or valve seals. A compression test can tell you if you have a good seal around the rings.
-Kai
bigjae19761569.50 M3ANMACHINE929.50 |
12-04-2018, 08:59 PM | #10 |
Rep 8,075
Drives: 11 E90 M3 Individual
Hard to tell from a close up shot.
All of the s54's I've dismantled have a coating of carbon on all of the piston crowns. Try using a fuel additive like Techron more often. I throw a bottle in every oil change.
2018 F30 320iX Melbourne Red
12-05-2018, 09:58 AM | #12 |
Rep 142
Not a problem, everyone has to learn somewhere. Part #6, seals off the valve guide so excessive oil doesn't seep down into the intake/exhaust track in the head.
-Kai
12-05-2018, 02:15 PM | #14 |
Rep 3,964
Sorry my mistake
Dave
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk Last edited by Dave07997S; 12-05-2018 at 03:05 PM.. |
12-05-2018, 03:43 PM | #15 |
Rep 10,594
Buying the seals is the easy and cheap part of changing them. Labor will be a lot more. I would leave well enough alone.
12-07-2018, 09:13 AM | #17 |
Rep 413
Compression test will not tell you if the oil control ring is doing it's job. I've also never seen a valve stem seal issue on an s65 or s85 that hadn't been "rebuilt" (meaning half ass taken apart and put back together).
You might consider looking at PCV related things too. |
IanMan384.00 |
12-08-2018, 01:11 PM | #19 |
Rep 79
Hi,
There are two different tests you can run: * Compression test: Where you measure the amount of pressure build-up that the piston does on its stroke. An adapter with a hose is screwed in instead of the spark plug, and you use the starter motor to go through 3-4 strokes for each cylinder. * Leak-down test: Where you measure the flow and pressure drop of air injected into the cylinder from your air compressor. While doing this test the engine is not moving, and you set it to a position where the valves are not open. The leak-down tester also screws into the spark plug thread. The equipment has an air regulator and two gauges. You can usually buy both these testers from Ebay for under $100 each if you are into DIY, but it wouldn't cost you more than 2 hours labour to let a workshop do the testing for you either. There would be a few tricks to get correct readings, and diagnose correctly, so could be best to let a workshop do it for you. Cheers, |
12-08-2018, 02:23 PM | #20 |
Rep 10,594
I think it will be more than 2 hours labor to test 8 spark plug holes and rotate pistons. And there is wait time on the leak down.
