07-15-2014, 12:18 PM | #1 |
Rep 2,932
FS 6 speed E46 M3 low miles meticulously maintained
The basics:
2002 M3 Coupe I am the second owner and Located in Central NJ Never winter driven (or rain unless caught in it unexpectedly a few times) Garage Kept by both myself and the previous owner No Accidents or Bodywork (Except for Euro front bumper, paint is perfect) 6 Speed Manual Titanium Silver Metallic Imola Red Interior (Cleanest you will find, the pics speak for themselves) 52,xxx Miles Asking Price: $24,500 Please PM me if interested. Contact number: 732-887-8922 (call or text, text preferred for fastest response) Factory Options: Premium Package Cold Weather Package Bi-Xenon Lights (Automatic) Side Rear Airbags (Very Rare) Harmon Kardon Sound Navigation System (Upgraded to the MKIV DVD Computer with wide screen and CD player up front) Seats are power with Lumbar, Adjustable Bolsters, and Heating Modifications I have kept the modifications fairly subtle, they consist of the following: Engine JVT headers (perfect fitment with thin flanges and O2 sensor locations) Evolve Tune with all the options, shift lights, linear throttle, O2 catless ready, variable rev limit per gear, sport button memory. BMW Coding All windows up and down with key remote One touch up Rear Windows Reverse Mirror Tilt Memory (allows you to set the position of the passenger side mirror instead of just tilting down in reverse) Euro Light Coding (Allows Bi-xenon high beams, halogen highbeams, and fog lights to be on at the same time) Cosmetic Exterior Blacked out OEM Side Gills and Front Grilles for excellent fitment New Headlight Lenses and Corners (had clear bra so they are perfect) No reflectors and no plate holes on front bumper (Euro OEM) CSL Style Carbon Fiber Splitters Interior Black Alcantara Shift and Handbrake boots with red stitching Brushed Steel Interior Trim ZHP Shift Knob and 330d short shift lever Upgraded Navigation System to OEM BMW MKIV (latest version found in the E46, same as 2006 models) 20% Carbon Window Tint to protect the gorgeous Imola Leather Maintenance TWS 10w60 Oil Changes Every 5k miles Updated Vanos Bolts and Hub Inspected on 5/31/2014 New alternator, Belts and Tensioner Pulley on 6/1/2014 OEM Clutch and Flywheel (Defective pressure plate caused slipping so I wanted to do it right and replace everything while in there). I have old clutch and flywheel to show this was not due to any sort of abuse. Shifter Bushings Engine Rear Main Seal (Preventive while doing clutch) Rear Trailing Arm Bushings with Limiters (preventive) Front Control Arm Bushings (preventive) Rear Diff Input Seal CPV O-Ring (preventive) Inspection II completed: All filters (Cabin, Fuel, Air) Spark Plugs Transmission and Diff Fluid Valve Adjustment Valve Cover Gasket Alignment Rod bearing recall has been completed 1,200 mile service h Subframe and Vanos are perfect with no issues, have PPI reciept from reputable shop. Carfax Available I am sure I am leaving some things out so I will update this as I think of additional items and go through my paperwork. If you are looking for a clean, enthusiast owned and well maintained car this is the one. If you want an M3 for a deal or "bluebook value" which is useless for these cars, please look elsewhere. I have helped friends search for their own M3's over the past year or so so I know what's out there, you get what you pay for. Thanks for looking!
