05-04-2020, 09:41 PM | #1 |
Rep 90
Shifter Boot Clips / Plastic Boot Frame (3D Printed)
I have designed improved clips for eBay shifter boot holder. It broke on me in a week after I had glued my new F10 shifter on. So I had 2 options, removing shifter boot from the plastic and buying a new one, or designing new clips which will hold up forever. That eBay one has very fragile clips, so I replaced all of them with my design clip and voila... It snapped in the place like a champ. These clips are printed with PETG, so very flexible and won't break in high temps or even if you bend it 180 degrees. I'm out of the market and do not print any new frames or clips, but I decided to make the project open and free for everyone. Here's the link: https://www.printables.com/model/345...rame-and-clips Donations would be appreciated. Thank you everyone! Last edited by buglinjo; 12-20-2022 at 09:38 PM.. |
05-05-2020, 11:08 PM | #5 |
Rep 90
05-08-2020, 02:39 PM | #9 |
Rep 90
05-08-2020, 04:37 PM | #10 |
Rep 818
Gotcha. Can you elaborate on filing the spot down? Did you use some sandpaper to rough up the area behind the old tab, sandpaper for better adhesion, etc?
05-08-2020, 06:13 PM | #11 | |
Rep 90
05-08-2020, 06:19 PM | #12 |
Rep 1,266
I’ll take a set, DM me your PayPal info please.
2015 BMW X5 ///M | Donington Grey | Aragon Brown MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby 2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown |
05-08-2020, 07:10 PM | #14 |
Rep 818
05-09-2020, 08:41 PM | #17 |
Rep 90
05-15-2020, 06:19 PM | #21 |
Rep 209
Drives: 2018 X5
So I bought some of these clips from buglinjo. They were ABSOLUTELY PERFECT! Not only were they shipped quickly, but the fit was perfect. Well, made and the design is MUCH better than the OEM clips.
I had installed the new M5 knob and the leather is much thicker. Nicer than the original M3's, I really liked the new leather but the original clips would not take. I trimmed to the point that there was barely enough on the plastic frame but the original clips still would not engage. After the clips arrived, I used a small hacksaw blade (for metal) to slowly cut off the original clips and then the inside edge (bump) that was part of the clip - made it all smooth. I used J&B epoxy and some of the metal binder clips to hold the new clips in place while the epoxy cured. After wrestling with the shift boot with the original clips I was ready for a fight trying to get the revised boot to snap in. Attached the wire and pressed the plastic ring into place. It attached immediately and perfectly. The fit is great. Done-finally. A long post for some plastic clips but they made all the difference. If you're thinking of the knob/ boot mod for the M3, use these clips. I would have saved myself significant trouble if I had installed these clips from the start. Nice work buglinjo! Last edited by Johnr3524; 05-16-2020 at 05:59 PM.. |
buglinjo22.50 |
05-15-2020, 06:27 PM | #22 | |
Rep 90
I'm glad I helped other people like me struggling to keep boot holder in place. |
SilverSlug680.00 |
