      12-28-2018, 12:37 AM   #1
zayn17
No sound from speakers
Hi guys, I have an 08 E92 M3 and have the individual audio I believe (the best one). When I start my car no sound comes from speakers whether it is the radio, cds, or aux. It has only happened to me 3 times while I have had the car (3 years now) but just happened twice within about a month. Usually works again after I drive and then turn it back on again. I don’t think it is the amp as i just got a replacement because the other one was water damaged. I know it isn’t a permanent issue and most of the time I have sound, but does any have any idea what could be causing this?
      12-28-2018, 09:15 AM   #2
mapster37
mapster37's Avatar
Drives: F80
sounds like the ccc is having issues, does the controller operate normally when sound issue is present? does the cid (display screen) change as requested?
wfdeacon881105.00
      12-28-2018, 04:12 PM   #3
Makaveli7
Enthusiast
Makaveli7's Avatar
Lebanon
117
Drives: M3 E92 Jerez Black
Just faced this on a frds E60 which had fiber optic cables near the amp loose, and a control unit submerged in water. Any codes are thrown ?
'08 JB E92 m3 // CCB Brakes // ESS 625 //
https://www.instagram.com/makaveli777/
      12-28-2018, 04:47 PM   #4
ItsGary
ItsGary's Avatar
Drives: 2009 E90 M3
Won't throw codes unless its all unplugged.
OP, check if you have water in the trunk again.
'09 335i Coupe - Alpine White/Black - SOLD
Makaveli7116.50
      12-28-2018, 04:58 PM   #5
wfdeacon88
Drives: E90 M3
FYI, similar thing happened to me on my previous 08 335, ended up needing a whole new ccc unit. Screen worked, all controls worked, but zero sound from every input type. Fortunately, I never fixed it and the car was totalled months later.
      12-28-2018, 07:14 PM   #6
zayn17
Yeah screen works fine. I can change the radio and go on nav etc
      02-02-2019, 11:45 AM   #7
jvictormp
jvictormp's Avatar
Brazil
881
Drives: 2008 M3 E92 6MT
zayn17,
Did you find out what the problem was?
Having same problem here with the E92 M3 I'm thinking on buying.
      01-02-2020, 03:53 AM   #8
zayn17
Originally Posted by jvictormp View Post
zayn17,
Sorry for the very reply. Water leaked inside the trunk through a gap in the left taillight and got on the amp. Had to get a new amp and now its fine
      01-03-2020, 06:44 AM   #9
ItsGary
ItsGary's Avatar
Drives: 2009 E90 M3
zayn17,
Called it. I had a similar issue but I was able to save my AMP
      01-04-2020, 10:41 PM   #10
jvictormp
jvictormp's Avatar
Brazil
881
Okay, no problem.
The previous owner replaced the amp, but now I need to know how to prevent this of happening.
Do I need to extract the tail light?
      01-07-2020, 10:06 AM   #11
ItsGary
ItsGary's Avatar
Drives: 2009 E90 M3
Okay, no problem.
Remove the tail light, clean up the surface and reinstall the tail light properly.
jvictormp881.00
      02-26-2021, 10:46 AM   #12
ssatvat
Drives: BMW 328i
I was able to fix the same issue in 2007 BMW 328i Convertible E93
See the details here:
      03-16-2021, 11:38 AM   #13
jvictormp
jvictormp's Avatar
Brazil
881
Thanks for posting. So your problem was the MOST unit? You bypassed it (only the optical fiber) and all came back working?
      03-16-2021, 06:30 PM   #14
Redd
Interesting. The unit below the telecomm unit that he bypassed, what unit is that and what does it do? I wonder what functionality was lost with the optical bypass.
jvictormp881.00
