11-03-2017, 03:40 PM | #1 |
Rep 256
Anybody have any experience with this in their car? Not installing it but impact to drivability. I have always installed light flywheels in my bikes and it's made the throttle response much better and the bike therefore more fun.
11-03-2017, 06:30 PM | #2 |
Rep 657
I had a lighter weight single mass flywheel installed on my corvette before i sold it years ago. didn't like it. the chatter was annoying at idle and the noises at low rpm driving were terrible...it was like you were lugging the engine. so that's just my non-expert experience.
11-03-2017, 09:24 PM | #3 |
Rep 1,239
i agree, the chatter associated with a lightweight fly is not worth the trade off. i rather go with shorter gears like 3:73 with the differential.
11-04-2017, 08:53 AM | #4 |
Rep 2,907
Drives: 2011 E93 M3
Your inquiry mentioned driveability. Driveability will suffer and depending on the setup, you'll likely get clutch rattle. Clutch engagement from a standing stop becomes touchy. Once moving and in the RPMs, the lighter flywheel will allow faster RPM adjustments when shifting etc.
A different animal from bikes. |
M3E90sedan108.50 |
11-04-2017, 09:00 AM | #5 |
Rep 1,913
Drives: Here and There
Could be fun at speed for quicker RPM changes in a purpose car (track car), but driving around town would not be fun in my opinion.
11-04-2017, 11:47 AM | #7 | |
Rep 2,907
Drives: 2011 E93 M3
Old flywheel/clutch assembly weighs 21.4kg New flywheel/clutch assembly weighs 21.96kg If those weights are accurate, I doubt anyone could tell a difference between the two. |
11-04-2017, 02:52 PM | #8 | |
Rep 386
I noticed no difference after mine was replaced. |
11-04-2017, 03:57 PM | #9 |
Rep 356
a true LWFW should notably improve throttle response and helps rev matching when downshifting. It does add noise/chatter at idle, but I consider it character to my gt3. Not sure if the results are similar with the s65, but worth considering if I ever need to replace my clutch.
11-05-2017, 09:09 PM | #10 | |
Rep 256
11-05-2017, 09:36 PM | #11 | |
Rep 2,907
Drives: 2011 E93 M3
Grabby clutches have to do with clutch selection, not flywheel. A lightweight flywheel will make it easier to stall from a standing start. |
11-06-2017, 09:47 AM | #12 | ||
Rep 256
11-06-2017, 10:32 AM | #13 | |
Rep 2,907
Drives: 2011 E93 M3
11-06-2017, 11:35 AM | #14 | ||
Rep 256
deansbimmer3748.50 |
12-07-2017, 01:01 PM | #15 |
Rep 256
So I got a jbr lightweight flywheel and oem luk replacement clutch. I'm looking forward to installing it but am worried about it being a non sprung hub clutch. Any thoughts or experience out there?
12-07-2017, 02:24 PM | #17 |
Rep 256
12-08-2017, 06:54 AM | #18 |
Rep 2,907
Drives: 2011 E93 M3
12-08-2017, 02:10 PM | #20 |
Rep 1,930
I had a single mass light weight flywheel with a stg2 south bend clutch on my G37 coupe. Stock's were a dual mass. There was a very loud chatter/rattle on low rpms but after a thousand miles or so it died down. I did notice the rpms did climb and drop much faster. chatter on idle did die down but was unbearable in the beginning. Also switched over to GTR fluid which I don't know if it helped.
Duk996245.00 |
12-08-2017, 02:54 PM | #21 |
Rep 256
I will! It's going to be a slow go though, the engine will be new and I will have to break it in...we should get a good understanding of how bad it is at idle though....which is where it's most annoying I guess.
04-22-2018, 02:15 AM | #22 |
Rep 52
So any news on this? i wonder how the jbr lightweight flywheel and oem luk replacement clutch ended up turning out as i'm also considering this when the clutch is toast which may be in the next year as i'm nearing 81k miles.
Assimilator1591.50 |
