      03-21-2019, 08:46 AM   #1
drivetolive
Drives: Z4M Coupe
Scratched CIC Screen Repair?
My CIC screen has quite a bit of scratches that are bugging me. Has anyone tried Meguiar's PlastX to get rid of the scratches and restore the screen?
      03-21-2019, 09:05 AM   #2
Dpc2u
Dpc2u's Avatar
Drives: E93 M3, E60 M5, F15 X5, E46
I used a 3 step polish from Novus I got on Ebay and then covered with a screen protector from NuShield which was a perfect fit. I did remove the screen from the car to do it which is very easy. End result is better than factory imo, and has lasted 8 months with no problems at all.
Edit- BTW, for the best results, polish of ALL of the factory anti-glare coating.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus
      03-21-2019, 11:15 AM   #3
dparm
Stop the hate, get a V8
dparm's Avatar
I did this as well and even after 4 years it still looked perfect. Previous owner of my car used to keep their sunglasses in there so of course there were a ton of scratches on the blue AR coating. Moron.
It's a bit time consuming but I wouldn't say it's that difficult. You can also just buy a replacement used screen on eBay if you want the 5 minute solution.
Past: 2011.5 M3 sedan ZCP
      03-21-2019, 11:39 AM   #4
drivetolive
Drives: Z4M Coupe
Thanks for the responses. Seems like there's a ton of solid reviews for Novus which I think I may be better off with.
      03-21-2019, 09:35 PM   #5
Redd
I had scratches on my iDrive screen too. Depending on how bad they are, you may be able to just apply a matte screen protector. I did that (without polishing off the AR coating) and the matte screen protector made 95% of the scratches invisible. Only the really bad ones were slightly visible from certain angles under direct lighting. Needs to be a matte screen protector tho.
      03-22-2019, 05:51 PM   #6
InnerBlueSkies
InnerBlueSkies's Avatar
1093
Drives: 2008 E90 M3
Yes, and it works!
      04-22-2019, 09:31 AM   #7
doogee
doogee's Avatar
748
Keep in mind what you're doing is removing the anti glare coating.
      04-22-2019, 02:37 PM   #8
drivetolive
Drives: Z4M Coupe
Thanks. The plan is to install a new glare coating once the original has been removed.
I still haven't found the time to tackle this, but once I do, I'll report back with my results.
      04-22-2019, 07:52 PM   #9
TomHudson
Drives: 2011 E90 M3
Weird TV experience when my kids scratched the TV.
I used a but of Vaseline that filled the scratch and has the same optical quality as the screen...scratch just disappeared....
      02-24-2020, 11:20 PM   #10
SoCalRPM
SoCalRPM's Avatar
886
Drives: e92 M3
Just today noticed a scratch in my screen. Argh.
Is the consensus to polish down. Make me nervous - never polished an lcd screen...
      02-27-2020, 05:26 PM   #11
MechEngineer408
Drives: 2013 E92 M3
I used PlastX to polish out my screen. Took a lot of elbow grease but it came out well. If you're OCD like me make sure to remove the screen from the dash so you can polish all the way to the corners.
      03-18-2021, 10:13 PM   #12
JJH
JJH's Avatar
Australia
544
Drives: IB E92 M3 DCT; SG E90 325i
I’m just about to do a CCC to CIC retrofit and the ‘new’ screen had fine scratching on the AR coating. Rather than using any of the polishes mentioned in this thread, I used sunscreen. Yes, sunscreen as in what you apply to your skin to prevent sunburn. No hard rubbing or polishing required. Just smear the lotion over the screen and let sit for a while. The stuff dissolves the coating and just you just simply wipe away.
Ajolives922.00
      03-18-2021, 10:20 PM   #13
roastbeef
roastbeef's Avatar
How do you guys scratch the screen? I don't think I've ever touched it.
      03-18-2021, 10:30 PM   #14
Redd
Previous owner liked to use the area in front of the screen to store his keys or phone.
      03-18-2021, 10:35 PM   #15
JJH
JJH's Avatar
Australia
544
Most likely the same with mine. All the scratching on my screen was on the lower edge ... the most visible part too!
      03-18-2021, 10:48 PM   #16
roastbeef
roastbeef's Avatar
Well at least you know they drove it like a grandma... nothing I'd put up there would stay very long.
Ajolives922.00
      03-19-2021, 10:32 AM   #17
wootloops
wootloops's Avatar
355
Drives: 2013 E92 M3 Lime Rock Park
I used the novus polish on one of my CIC screens. It worked but it took a lot of elbow grease. To be honest, I was not really happy with the lack of anti-glare coating after it was done. I ended up buying an early CIC screen off ebay with the plastic cover over it so it didn't have scratches. I think it was like 2009 and 2010 model years. For about $120 it was worth it to me.
      03-22-2021, 12:25 PM   #18
Patcho
Drives: 11' E90 ZCP IB, 23 G80 M3 Cx
Don't you have holes in yours?
      03-22-2021, 02:11 PM   #19
roastbeef
roastbeef's Avatar
Not yet.
Patcho98.00
