      02-27-2017, 08:10 AM   #1
Redd
Ohlins R/T Settings
Please share your Ohlins R/T damping settings for:
Comfort - F/R
Spirited Driving - F/R
Track - F/R
Measured in clicks (0 being full hard). Thanks.
      02-27-2017, 11:04 AM   #2
benchan78
Drives: 2008 E90 M3
i've experimented around a bit. i like 13 13 for all street situation. going stiffer makes the car more responsive and roll less, but too stiff also reduces traction and grip, i find. on the other hand, going softer than 15 makes the car too wobbly and soft. what are your settings?
      02-27-2017, 11:10 AM   #3
Datka
Datka's Avatar
450
Drives: 2009 M3 ,2021 M340i
Comfort - F/R-14/14 clicks from full hard
Spirited Driving - F/R no more spirited driving for me anywhere other than track
Track - F/R-2/4 clicks from full hard
Also would like to hear what settings are other drivers running
"Racing is life. Anything before or after is just waiting." Steve MCQueen
      02-27-2017, 05:42 PM   #4
Redd
I just had mine installed, hence asking for settings suggestions.
Currently running 12/12 for street which I find is one level firmer than stock and still comfortable with good body control. I'll be sticking with this for daily use.
Haven't had a chance to set it up for spirited or track driving yet.
      03-01-2017, 03:09 AM   #5
becausephilchow
Drives: 08 E90 M3
I use 9/9 for street.
      03-01-2017, 03:30 AM   #6
Redd
Wow, you must have good streets where you live.
      03-02-2017, 08:17 PM   #7
becausephilchow
Drives: 08 E90 M3
Truthfully, not really. Although it doesn't snow in Hong Kong, our roads are pretty crappy for what it is.
Too many trucks using our roads. They're not bad, but I wouldn't say they're great.
      03-03-2017, 06:47 PM   #8
Revvvm3
Revvvm3's Avatar
Drives: AW E92 M3
8/8 for spirited driving, wouldn't mind driving it like this daily. Super comfortable set of coilovers.
Instagram: @m.ch.ael
Current: Yas Marina Blue M4
Current : Mini Cooper S R56
Sold: E46 M3/E92 M3
KW | Fall line | Volk Racing | Recaro | Bayoptiks | BM3 | THOR | IND |
      03-09-2017, 12:38 AM   #9
6ixSpd
Save the manuals!
6ixSpd's Avatar
6015
Drives: '16 M3, '23 718 Spyder
That dual flow valve technology is a wonderful thing! Ohlins FTW.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      03-09-2017, 01:13 AM   #10
Redd
Definitely! Can't imagine how comfortable it can be til you drive it!
      03-09-2017, 11:05 AM   #11
Datka
Datka's Avatar
450
I have seen a few posts where some members replaced this system with more track oriented coilovers like JRZ Pro, MCS, KW clubsports, ect..
Personally, I track my car with Ohlins R&T and really like it.
Car feels great on the track, huge improvement from stock.
Is it as good as above mentioned systems?
Maybe, I will be able to tell only if I drive the same car with different coilovers and compare the data.
As of now, I have no plans to remove something that has worked for me well.
Just on the side note, I have run against other similarly prepped/same tires e9x m3s but with so called more track oriented coilovers in the advanced/instructor run groups and I am as fast or faster.
      03-09-2017, 02:35 PM   #12
Richbot
Drives: Jerez Black E90
There's a lot of nonsense out there about stiff springs making cars faster. With aero and low ride height targets, I suppose it starts to be true, but there's no reason a setup like this, which remember still more than doubles the stock front spring rate, can't be just as fast on track as something much fancier and stiffer on a 200tw street tire without real downforce on the car. On street tires good damping and springs that allow the suspension to move, but keep it in its geometry happy place, are all you really need.
One caveat being that as soon as you start dropping the car down really low, I doubt the R&T has enough front spring to keep the car out of the bumpstops and/or keep it from whacking fenders, so a higher rate front setup might have some advantages for getting the car low, but who wants to be that low on the street anyway
      03-09-2017, 03:57 PM   #13
Datka
Datka's Avatar
450
I forgot to mention that I also have front Dinan sway bar installed on mid settings that seems to keep front of the car from too much body roll and feels almost perfect to me.
      03-09-2017, 05:09 PM   #14
Redd
Same here, I have H&R sways front and back. Seems to be a good combo.
      03-14-2017, 08:59 AM   #15
e46e92love
e46e92love's Avatar
Drives: e92 ///M3; X3 (wife's)
It's because the more advanced true 2 / 3 -ways require advanced knowledge of suspension tuning to get the dampening / rebound (multiple speed settings) right. This may lead to further complication when taking into account the differences from track to track needing adjusting for each.
Those more advanced settings are FAR from set it and forget it. So many of the cars you have run against probably are not tuned right for the track you are on. Few people can take advantage/ know how to take advantage of the more advanced setups, but they have been sold it makes them faster. Kinda of like people upgrading the power when none of them can run the ring or any U.S. Track even CLOSE to the track's best times set in a STOCK M3.
Cheers,
e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan.
      03-14-2017, 10:14 AM   #16
Richbot
Bump adjustment on 2-ways is not rocket science and is mostly set-and-forget if you're running the same setup and track often. Having access to bump adjustment is a huge help for trackside tuning, and it's not as hard as people make it out to be, you're usually moving 1 or two clicks from your baseline if that to account for changed tire/surface conditions
But I agree for most people just a rebound knob (or no knob, what the hell is wrong with tire pressure?) is enough to get them through 95% of tuning situations, and makes life less stressful
The top-down parts high-end availability for this platform is one of the most annoying things about it. Want a piece of bent tube with two flat plates welded to it? THAT'LL BE $450.
      03-18-2017, 06:39 AM   #17
su_root
Street/Spirited/Track= 5F/10R
I pulled these settings off of Ohlins project car article they posted on their website.
TBH, Haven't tried any other settings but these settings feel fine and The car feels a lot more planted, closer feel to my F82 which is a lot to say
      03-18-2017, 08:01 AM   #18
Redd
Any link for this article?
      03-18-2017, 01:27 PM   #19
su_root
Sure.
http://www.roadandtrackbyohlins.com/
Then click the link for 'Project Car'...about 3 articles down from the top
      03-18-2017, 06:47 PM   #20
Redd
Thanks!
      03-18-2017, 08:07 PM   #21
e46e92love
e46e92love's Avatar
Makes sense, softer suspension (allow the car to squat in the drive wheels) like "fatter tires" contribute to better traction on cars acceleration.
Cheers,
e46e92
      03-18-2017, 09:46 PM   #22
Redd
But the prevailing mentality for most Ohlins users is equal (or nearly) settings F/R. Even the Ohlins installation guide recommends that. I'm confused.
