02-14-2018, 01:20 PM | #1 |
Rep 124
catless and tune NY inspection time, what to do?
so im running catless x and gintani tune and my inspection has been expired but i dont think i will pass because on my scanner the 02 sensor and catalyst monitoring comes up as incomplete (from the tune i know)
ive searched a lot and some guys say theyve passed with catless + tune but i dont know how that would be. anyone have experience with this in ny? is there any way around this other than removing xpipe and flashing back to stock? |
02-14-2018, 02:06 PM | #2 |
Rep 1,287
If your rear o2’s are turned off in the tune to keep the cel from coming, then you won’t pass. You can’t pass with two monitors not set in this part of ny and the two o2 monitors wont set with the rear o2’s turned off. I’ve had fair success with the stock ecu and using defoulers on the rear o2’s. Just gotta drive easy for the monitor to set and keep driving easy till inspection.
02-14-2018, 02:10 PM | #3 | |
Rep 124
02-14-2018, 02:32 PM | #4 |
Rep 1,287
So i’m not fully catless. Running arh headers with highflow cats. Somehow i doobt those cats do anything though. Stinks like a bitch lol. I used the defoulers they provided. I’m gonna run catless on my other m3 with stock headers and I bought these defoulers to try: http://www.bigdaddiesgarage.com/stra...MaAkyuEALw_wcB
Apprently autozone sells some too but these looked nice. |
02-14-2018, 07:22 PM | #5 | |
Rep 124
02-27-2018, 09:48 PM | #6 |
Rep 164
Currently running fabspeed primary hfc and secondary delete xpipe. I’m also running o2 sensor spacer. No cel ever came on and last year I was able to inspect my car no problem. Finally got a tune done through Gintani and I went to go get my inspection done today and it failed. Said cats and o2 sensor not ready. Seems like gintani is shutting those two sensors off with tune.
Any way around this? I was told by them that I wouldn’t have an issue with getting inspected when I called to get my car tuned. |
02-28-2018, 12:46 AM | #7 |
Rep 850
If it is a new flash then your car is not in "ready" state. You need to do the emissions test drive reset following the formal procedure, or just drive around a while and it will eventually clear. You can easily google it but basically it involves idling for 5 minutes from cold start, driving slowly uninterrupted, driving at a faster speed uninterrupted, then stopping and idling again.
03-01-2018, 01:21 PM | #8 |
Rep 227
Drives: E92 M3- AW
Was having this same quandary, as I'm due for inspection at the end of the month too.
With my current setup every 2 years I need to swap the stock X-pipe back in and flash back to the stock map. Currently running a ESS Tune, which is pretty easy to undo. Lots of mixed reviews on whether or not the defoulers actually work, but it would be nice to not have to put the stocker back on. I have it down to the point that it takes me less than a few hours to put the stocker back and then an hour or two to swap back to the catless. Was thinking about a catted X-pipe but they are pretty pricey, and seems like very few manufacturers even have them anymore.
Alpine White E92 M3 - 6MT
ESS Tuned |
03-07-2018, 08:03 PM | #11 |
Rep 124
ehh that's a lot of work compared to twisting on a couple spacers. just wanna know if its worked for others before i waste 70 bucks and my time
03-12-2018, 07:02 AM | #14 |
Rep 124
03-13-2018, 10:42 AM | #15 |
Rep 66
I have the Evolve tune over 6yrs, 3yrs with the full Akrapovic Evo and 3yrs full catless Akrapovic GT4. I have no problem doing inspecetion every year, but I think I had change the O2 sensors 2 or 3 times in 6 years. Do you want to bring your car to my mechanic to let him take a look? PM me your number if you want to do it, he is at Sunset Park Brooklyn.
03-13-2018, 11:40 AM | #16 | |
Rep 124
05-07-2018, 08:52 AM | #21 |
Rep 1,227
05-07-2018, 09:10 AM | #22 | |
Rep 916
http://www.motoiq.com/MagazineArticl...aust-Tips.aspx |
M3LISSA786.00 |
