BPM
      01-31-2018, 01:25 PM   #1
rmtdewz
Drives: 08 E90 M3 6MT
2008 E90 Oil in Coolant
Anyone ever get a little oil residue in the coolant reservoir?
      02-02-2018, 10:21 AM   #2
Helmsman
Helmsman's Avatar
Sweden
4421
Drives: 2011 AW E90 M3 ZCP
Ups, never heard of but lets see what the tech guys says. Previous owner did oil top up a late Saturday night..?
      02-02-2018, 10:32 AM   #3
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
Coolant should be blue
      02-02-2018, 11:18 AM   #4
pbonsalb
Has not been an issue I recall reading about in my 7 years here, but I agree it does look like you have oil in your coolant. I don’t know the most likely culprit. The OP mentions the oil filter housing gasket. I have not studied it and am not sure whether coolant passes through it.
      02-03-2018, 01:59 PM   #5
rmtdewz
Pulled the oil cap, no milky looking coolant mixing under there. Pulled the oil filter, looks normal. From what I can tell in the diagrams it looks like the coolant flows through the oil filter housing.
      02-03-2018, 03:16 PM   #6
///M Power-Belgium
General
///M Power-Belgium's Avatar
Belgium
63013
Drives: ///M3-E92-DCT Silverstone II
Originally Posted by rmtdewz View Post
Just purchased a 2008 E90 M3 with 41,000 miles. After checking it over noticed oil residue in the coolant tank. Coolant looks very oily and after dipping my finger in it does have quite a bit of oil in it. Anyone seen this as a common thing with these cars?
My first thought is oil filter housing gasket..
Attachment 1761231
Attachment 1761232
Oil in coolant is one of the symptoms from a *Blown Head Gasket* !
Someone pulled high rpm's while your S65 was still cold...
#reallysucks !
kyrix1st2356.50
DrFerry6725.50
      02-03-2018, 09:18 PM   #7
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
I've seen this before and it might be no big deal. Put a shop towel in there and soak up the goo. Do that several days in a row and see if the amount on the rag is the same.
You could always do a coolant flush and see if the oil comes out. Sometimes there's oil in there during assembly, but I'd have expected your car to have had several coolant changes by now (every 2 years it should be done iirc).
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      02-03-2018, 09:35 PM   #8
pbonsalb
I don’t think factory spec coolant changes are 2 years. Probably 100k miles.
      02-04-2018, 11:44 AM   #9
///M Power-Belgium
General
Belgium
63013
I agree . I have 54K km on it , and I never had a coolant change .
Oil in coolant is always a bad sign , like I said above ...It's the symptom of a *Blown Head Gasket*
I wouldn't drive my car like this , the chance of overheating and compression loss is big...
A lot of *white smoke* from the exhaust tips , and the smell from coolant can show what is going on..
      02-04-2018, 11:53 AM   #10
GORDON.M3
GORDON.M3's Avatar
Drives: E92 M3 • F25 X3 M-Sport
Wow... only 41,000 miles and there's oil in your coolant expansion tank? That is horrible...
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
      02-04-2018, 12:40 PM   #11
Cbozz
Cbozz's Avatar
Drives: M3
It could be a bad Oil Filter housing gasket -- that's where oil flows next to coolant and if gasket is bad they can mix....
and I think the reason why oil in the coolant and no coolant in oil is because oil runs at higher pressure ....?
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      02-04-2018, 01:25 PM   #12
rmtdewz
Eh
      02-04-2018, 03:57 PM   #13
pbonsalb
If it’s just a gasket, that can be fixed. I am more concerned about why it happened since no one seems to suffer this problem.
      02-04-2018, 05:40 PM   #14
admranger
Retired Curmudgeon
admranger's Avatar
Good point. I had my E46M3 thinking cap on.
I'd pull an oil sample and send to Blackstone. They'll let you know if you have water in the oil.
It's likely the oil filter housing gasket. It shows up as an issue when you google oil in coolant m3 or things like that.
I'd still try to soak up the oil in the coolant tank and see if it comes back. Someone may have put an additive in that has aged out and now looks like oil too. Unlikely a head gasket unless the motor has been severely overheated.
      02-04-2018, 05:57 PM   #15
pbonsalb
http://www.m3post.com/forums/showthread.php?t=1312849
I can’t see how the coolant is getting into the oil. The guy removed the water pump but I think that was for access.
      02-04-2018, 07:52 PM   #16
rmtdewz
Well
      02-04-2018, 08:02 PM   #17
pbonsalb
If it’s getting in from the engine, it may be a head gasket. Big job.
      02-04-2018, 08:56 PM   #18
rmtdewz
Hmm
      02-04-2018, 09:03 PM   #19
pbonsalb
It would make me think maybe the seller knew and sold the car to avoid problems.
      02-04-2018, 10:47 PM   #20
GORDON.M3
GORDON.M3's Avatar
Oil in your coolant like that is pretty game over. You will need to rebuild the engine, probably might as well do the bearings also, main and rods.
If I were you though, I would go straight to the dealer as they sold you a lemon.
      02-04-2018, 11:51 PM   #21
M43S7RO
Drives: Jerez Black E92 M3
Lemon laws in your state?
      03-04-2018, 07:28 PM   #22
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
Any update op?
Search this Thread:
Advanced Search
