04-23-2020, 08:46 PM | #1 |
Rep 207
What's happening guys. Up until 3 weeks ago my car started making a clunking sound upon acceleration like a baseball bat banging against the shaft. Even when in cruising speed, pressing and decompressing the gas pedal, I can hear a clunk sound anytime I let off. My driveshaft was inspected and was apparently in good condition.
I'm running Turner solid Delrin diff. bushings and I'm assuming they put a ton of stress on my differential and damaged it. Could this issue be from the u-joint on the driveshaft or a diff. Issue. I included a video link down below so you guys can get an idea. Even with the driveshaft disconnected, it still made this sound. Assuming my diff is bad? Car is a 6MT [IMG][/IMG]
04-23-2020, 10:31 PM | #4 |
Rep 73
04-23-2020, 11:00 PM | #5 |
Rep 207
They are but they also allow no play for the differential, leaving all the power going straight to the diff. I believe they might've put a ton of stress on it and damaged it.
04-24-2020, 07:37 AM | #6 | |
Rep 73
04-24-2020, 01:23 PM | #7 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
When I replaced my driveshaft, the noise was a hollow metallic dink, since the driveshaft is hollow. The u-joint is not serviceable and wears. The center bearing is also a wear issue. You really hear the dink echo while driving in a parking garage.
Your sound might be the diff or half-shafts...but it could be the CV joint at the back of the driveshaft. The CV joint is packed with grease and ball bearings, and the grease eventually drys out, causing some noise. If you need to replace any driveshaft component, replace the entire driveshaft with a Turner Motorsports unit. It has a replaceable u-joint. They don't have them in stock at their supplier in Az, so they have to make one from a used core. Labor to replace driveshaft components is the same as replacing the whole thing. Best of luck, Cheers |
04-24-2020, 05:58 PM | #8 | |
Rep 207
04-24-2020, 09:05 PM | #9 |
Rep 787
04-24-2020, 09:08 PM | #10 |
Rep 207
Of course! I'll be posting pictures of the process
04-24-2020, 09:21 PM | #11 |
Rep 787
Apparently you opened other threads about the same problem.
I saw at one of them that you were getting wheel hop when spinning, right? Then you went to the very extreme solid bushings that caused this problem, now you're turning back to OEM. Do you think the wheel hop will be solved by the new OEM bushings? Shouldn't you try some intermediary option? |
04-24-2020, 09:36 PM | #12 | |
Rep 791
Good insight.
Solid bushings with wheel hop = Busted Diff. Hope the OP can confirm what happened and get it back on the road. Quote:
04-24-2020, 09:57 PM | #13 | |||
Rep 207
04-25-2020, 10:04 PM | #14 | |
Rep 787
Is your engine stock? |
04-25-2020, 10:42 PM | #15 | ||
Rep 207
04-26-2020, 06:38 AM | #16 |
Rep 10,616
Do you think damage could have been done from wheel hop while the old stock bushings were in place that you did not notice until after the solid bushings were installed?
04-26-2020, 10:19 AM | #17 |
Rep 207
Good point! Wheel hop does damage the diff. I'm sure they served their part and the solid mounts just finished the job lol
04-26-2020, 10:38 AM | #18 |
Rep 10,616
It the loss of traction and regaining traction during hop that shocks the diff and can break mounting bolts. I am curious what the problem is with yours but it may not be obvious without disassembly and some knowledge of how these diffs work. Is it a broken head tooth or axle spline or worn bearing or something is the lsd assembly.
04-26-2020, 11:02 AM | #19 | |
Rep 207
04-26-2020, 11:30 AM | #20 |
Rep 3,409
@boussi33 All you posts reference the differential mounts being upgraded. What have you done with the subframe mounts? Are they also upgraded?
04-26-2020, 11:32 AM | #21 |
Rep 207
No sir. They're still oem
04-26-2020, 11:43 AM | #22 |
Rep 10,616
Maybe the flex in them contributed to the problem. I would have done hard subframe mounts like 75D poly or Delrin or aluminum and not quite as hard diff mounts. I use 75D subframe and 95A diff, for example.
