04-15-2017, 01:03 PM | #1 |
Rep 313
GTS Wheels and Recommended Tire Size
Does anyone have experience with running a 275/30-19 or 265/30-19 (F) and 295/30-19 (R) on the 359M/GTS wheel without spacers? I have a non-competition package E92 M3 with stock suspension and I want absolute zero rub.
Thanks! |
04-15-2017, 08:56 PM | #2 |
Rep 2,653
The M3 GTS is equipped with 255/35-19 front and 285/30-19 rear tires from the factory. You could go with that fitment, or jump up to 265/30-19 up front.
- Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
04-16-2017, 11:38 PM | #3 |
Rep 561
04-17-2017, 12:11 AM | #4 |
Rep 2,653
Pirelli P Zero Corsa's, however you could go with Continental Extremecontact Sport, Bridgestone S0-4 Pole Position, or the Khumo Ecsta PS91 in the same sizes.
KawBoy154.50 |
04-17-2017, 07:11 AM | #5 |
Rep 313
Thanks for the help, but I'm really not a fan of the GTS sizes because the rear's are actually slightly smaller in diameter than the front's. I'm really on the fence with this! I want to maintain as much sidewall as I can because of the roads around here, but I also want as wide as I can go.
04-17-2017, 12:21 PM | #6 | |
Rep 191
04-17-2017, 01:39 PM | #7 | |
Rep 6,799
It is certainly possible to mount 275/30-19 on the front 9" wheels, and 295/30-19 on the rear 10" wheels, however this would not be ideal. From a handling perspective, it would be best to have wider front and rear wheels for proper sidewall support. - Ryan
04-17-2017, 01:52 PM | #8 | |
Stop the hate, get a V8
3853
Rep 8,625
I can tell you that even on a tire that's wide for its size, the 255/275 combo does not rub. It's still a lot of tire for a street-driven car.
Past: 2011.5 M3 sedan ZCP |
04-17-2017, 07:53 PM | #9 | |
Rep 561
04-17-2017, 08:33 PM | #10 |
Rep 313
I know a lot of people recommend 255/35-19 but I tried those (Michelin PSS) when I had my Morr wheels. They were a 19"x9" with a +22 offset, which put them 9mm further out than the GTS +31mm, and they rubbed on the inside wheel well when turned 1/2-3/4 of lock. I know they used this wheel on the GTS, but I wonder if they used a different liner or left it off all together.
04-17-2017, 10:32 PM | #11 |
3853
Rep 8,625
Depends on the specific tire. They don't look out of place and 9/10 people won't be able to tell the difference; those sizes just give you a much bigger selection of tires without making a big change to the overall size. The F80 M3/M4 actually switched to these sizes as OEM.
KawBoy154.50 |
04-18-2017, 10:07 AM | #12 | |
Rep 928
It should look pretty good and wide and it should even make the ride better. All that while improving performance and I think any size bigger is overkill. Stay away from the 30 sidewall it will only be a little wider but you sacrifice your ride quality significantly.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
04-18-2017, 10:54 AM | #13 |
Rep 313
Thanks for all the help! I may try the 255/35-19 & 275/35-19 again on these wheels. As I said earlier, this combination rubbed with my Morr wheels on the front axle fender liners, but I'm hoping the 9mm difference in offset will eliminate that. If it doesn't work, I may have some very lightly used tires for sale
04-18-2017, 03:18 PM | #14 | |
Rep 561
04-18-2017, 03:58 PM | #15 |
3853
Rep 8,625
The E9x ZCP wheels are 19x9 and 19x10. The F8x wheels are the exact same widths yet wear the 255/275 tire sizes I mentioned.
04-18-2017, 04:23 PM | #16 |
Rep 561
05-05-2017, 02:54 PM | #17 |
Rep 313
Well, I finally took the plunge and purchased Michelin Pilot Sport 4s tires in 255/35-19 and 275/35-19 yesterday for my M3. Thanks for everyone's input!
06-08-2017, 09:33 PM | #21 |
Rep 313
Well went with the 275/35-19 and 255/35-19 Michelin Pilot 4S and absolutely love the setup. Used McGard black lug bolts/locks, black valve stems and black wheel weights.
