12-04-2021, 07:47 PM | #1 |
Rep 215
so i bought the kit and happy with it decided to hook the camera finally and i cant get it to have a signal. i followed the following youtube video
i noticed the last wire he connects he says brown and yellow mines is brown and purple i even tried the green and red and nothing. i wasnt going to touch brown just in case its a ground wire. here are photos of my setup. i just reached out to the seller but doubt he can help. thanks i searched on google and the forums and cant find nothing. i would like to add in the video he dosent connect the red wire that cones out the video wire behind the monitor or use wire with the Chinese writing. |
12-05-2021, 02:23 PM | #2 |
Rep 215
anyone with this stereo system with a camera?
i connected directly to the battery minus the oem wire to unlock the trunk and nothing still. im starting to think i have a defective camera now. |
12-05-2021, 04:39 PM | #3 | |
Rep 121
At the front there should be a yellow rca rcam and positive wire rcam you should wire it up to. |
Angr238738.50 |
12-05-2021, 04:41 PM | #4 |
Rep 215
the stereo works . i was thinking about that red wire as well. in the video he dosent connect it. should i just link it to my fuse where i got my radar detector connected?
the stereo i got US $275.10 30% Off | 8.8" Wrieless Apple CarPlay Android Auto Car Multimedia For BMW E60 E63 E90 E92 CCC CIC System Head unit Rear Camera IOS https://a.aliexpress.com/_mMWwidc |
12-05-2021, 05:42 PM | #6 |
Rep 215
on the head unit the yellow rca is in the dvr one . the red is not connected . i just bought some red wire and going to connect it to the fuse that has my radar connected to
12-05-2021, 05:47 PM | #7 |
Rep 121
There should be a RCAM RCA you connect it into. Also, you should connect the red wire of the cam into the RCAM positive wire. If you have a picture I can show you what to connect.
Edit: For example, this head unit you connect RCA into 6 and the positive wire into 16. |
12-05-2021, 05:51 PM | #9 | |
Rep 215
so the red wire of the camera in the back has to be connected to the red wire in the front of the head unit? do i buy a long red wire and run it from front to back? |
12-05-2021, 06:00 PM | #10 |
Rep 121
I believe you have your wiring backwards, this is supposed to go into the android headunit along with the positive wire.
12-05-2021, 06:08 PM | #12 |
Rep 121
Gotcha, my bad. Take a look at this diagram in that case, it should solve your problems.
12-05-2021, 06:15 PM | #13 |
Rep 215
nice picture. from what i saw the front red wire has to be connected to a 12v source. the back red connects to nothing am i correct?
my front red is currently not connected to nothing and the back red was going into the rear harness |
12-05-2021, 06:24 PM | #14 |
Rep 121
Yes the front red connects to the radios RCAM 12v source and make sure the front RCA is in the radio's RCAM RCA.
The back red connects into the RED RCA cable and grounded onto a BROWN wire or any ground with a bolt. |
12-05-2021, 06:30 PM | #15 |
Rep 215
[IMG][/IMG]
this is the front connection the red i should connect to a fuse ? or to this cam power? i just noticed there is a purple wire in the front label cam power |
12-05-2021, 06:43 PM | #20 |
Rep 121
