11-10-2021, 07:54 PM | #1 |
Rep 50
Which Factory Woofers will work?
I have a 2011 E93 M3 and it has the silver trim on speakers so I think it has the sound package. The subwoofers under the seats don’t work, but they are getting a signal I hooked up a random test speaker to confirm.
Does it matter what under seat speakers I put back or will any plug in and work and mount up to the same holes as they should if I go to a salvage yard and pull some out? This is the part number from the one under passenger seat: zr783890801 |
11-10-2021, 09:24 PM | #2 |
mTekMods
2139
Rep 2,899
If you have silver rings then you need individual subs. The normal hk ones won’t hit like they should because the individual/topfi cars run at a different ohm.
