02-25-2010, 10:45 PM | #1 |
Moderator
673
Rep 4,737
Euro AP Racing BBK Pictures
From thorneymotorsport.co.uk.
http://www.thorneymotorsport.co.uk/e..._Upgrade.shtml Interesting to see a comparison between the US kit (Ø368F, Ø358R) vs. Euro kit (Ø378 or Ø368F, Ø350R). Looks like the biggest difference is the rear rotor and caliper, which is what Chris@Stillen has said before. Wonder what difference it makes? Last edited by rzm3; 02-26-2010 at 12:19 AM.. |
02-26-2010, 02:45 AM | #5 |
e36s54, e70x5d
151
Rep 1,723
very interesting ...... wonder why those colors are not available here?? .. hmmm
and why is there a difference of ANY kind if the kit is coming from the same place and built for the same exact car?? |
02-26-2010, 02:19 PM | #7 | |
Automotive Industry Insider
462
Rep 1,948
They get to decide what brake products are sold for each BBK application, and the final specs those parts will possess. If they determine that 90% of the BBK market will be better served by offering the 368f/358r setup (cost vs. performance), then that's the kit they will offer to the general public. It keeps the number of BBK configurations options simple, and it also reduces the number of replacement parts they have to keep in their warehouse. (for repair or routine brake service maintenance) Stillen & AP Racing work together (in a co-opertaive fashion) to engineer every big brake "kit" they offer here. Stillen does not simply order a pre-packaged BBK. (out of a catalog) There will always be options that get left out...in the pursuit of practicality. I suspect that Stillen has decided that a 386f/358r BBK combination, offers the best balance between braking performance, cost, and clearance for OEM & aftermarket wheel fitments. As a consumer, I always want all the options that I can possibly get (within reason of course), so I'm not a big fan of Stillen's decision to limit what I can or cannot buy here in the United States. That being said, I completely understand why aftermarket parts distributors sometimes choose this path.
The best is yet to come...
02-26-2010, 08:09 PM | #8 | |
Brake Maven
Rep 229
There are some cars in North America currently with the AP Formula kits installed front and rear. However, these kits are not normally stocked in the USA since the Stillen kit works beautifully and is already fully supported with replacement parts on the shelf. The UK Formula kits take typically take 10-12 weeks to arrive by ocean, but sometimes they beat this by a few weeks. Some people prefer to pay for air shipping, which reduces the lead time by about 4 weeks and increases the price by about $500 or so per car set. Truth be told, the caliper on the Stillen kit is a little stiffer than what was chosen on the Formula kit. It might not make that much difference to some, but they turned out to be sized correctly and were already stocked in the US. Had that not been the case, Stillen would have used the Formula kit caliper once it was ready. Stillen chose not to do a U.S. 378mm front kit as the AP Formula kit was already done. Some have been brought in by request on a per order basis. The 368mm kit was shipping in the USA before it was shipping in the UK. It was driven by Stillen for customers choosing to run 18" track tires, not that AP wouldn't have done it themselves eventually anyway. It just worked out that way on the E9x M3 as the UK did the larger kit first. No one likes to limit customer options. At the same time, customer service concerns dictate that replacement parts must be available when needed. I've seen situations where customers had rare or odd-ball setups (not always AP, but it has happened) and were told they had to wait a month or two for replacement discs. It's no fun fielding THAT phone call. No one I know needs a second anus! Chris P.S. I actually like the balance of the Stillen kits better. The UK went slightly more conservative, being the proper Brits they are. It's a very minute difference, but we think M3 drivers deserve the best we can give them. |
03-01-2010, 04:26 PM | #10 | |
Brake Maven
Rep 229
Chris |
03-01-2010, 05:00 PM | #11 | |
Rep 3,831
The rear rotors look to be different as well no?
03-01-2010, 05:30 PM | #12 |
Brake Maven
Rep 229
AP Formula rear kit: 350x26mm
Stillen/AP rear kit: 356x26mm Minuscule difference at the OD and even less so at the effective radius. This was another reason the decision was made to go with a rotor size already well stocked in the USA. The 350x26 had not been used on any previous brake system on this side of the pond. In fact, I can't find that same disc in any other Formula kit either. For a such a small change (less than 0.8% and in the right direction anyway), it is much better for customers to have replacements readily available. Chris |
03-01-2010, 10:13 PM | #13 |
e36s54, e70x5d
151
Rep 1,723
Are the front rotors (on the Stillen/AP kit) a US-manufacturer rotor (like Racing Brake) and the hats come from AP Europe?
Are the rear rotors (on the Stillen/AP Kit) a US-manufacturer rotor (like Racing Brake) and the hats come from AP Europe? |
03-01-2010, 11:54 PM | #14 | |
Brake Maven
Rep 229
The rear rotors are made to Stillen's design and engineering specifications by DBA (Disc Brakes Australia). DBA is also a technical partner to AP Racing, supplying rotors to OE applications as a direct subcontractor to AP. The rear hats are made by Stillen in the USA. Not that it is pertinent to this discussion, but all of Racing Brake's rotors are manufactured in Taiwan, not the USA. Is there a particular issue you are concerned with? Chris |
03-02-2010, 02:58 AM | #15 | |
e36s54, e70x5d
151
Rep 1,723
Ya ... u answered my potential issue .... IF u were using cheap rotors (like RB). Thanks 4 answering all questions regarding this kit ... i know it may seem like a pita ... but some of us more crazy enthusiasts really appreciate your answers. Thanks again. |
03-02-2010, 07:08 AM | #16 |
e36s54, e70x5d
151
Rep 1,723
Chris,
The Formula Kit is available on your website: http://www.stillen.com/product.asp?i...e=BMW&model=M3 would you recommend it over the other kit for people that track more often? Is it more of a 'race' kit (no piston dust boots, etc)? |
03-02-2010, 11:21 AM | #17 | |
Brake Maven
Rep 229
That said, I would not recommend against the 378mm, but it is only for those that never plan on using 18" wheels or who have purchased 18" race wheels that have already been checked for clearance. Most street-oriented wheels have too deep of a drop center and would crash into the caliper. Chris |
03-02-2010, 11:29 AM | #18 | |
Brake Maven
Rep 229
Chris |
