12-22-2009, 02:40 AM | #1 |
Let's Race
Rep 51
Eibach's take on Bumpstops
This is the answer I received from Eibach regarding the stock Bumpstops and installing their springs.
"Hello Tobbe, Regarding your question below. Our Eibach Pro-Kit for the 2010 M3 Coupe does not require modifications to the bumpstop. Our kit is made to work with the OE dampers and bumpstop as is. The kit is designed to have lowering of 0.8" at the front and 0.6" at the rear. There is still enough suspension travel before bumpstop contact with the lowering of our kit. The kit works great! You should not have any concerns. Please let me know if you have any other questions. Thank you for your interested in the Eibach product. Best Regards, Phong Diep | Research & Development Manager Eibach Springs, Inc. | 264 Mariah Circle | Corona, CA 92879-1751 T +1 951-256-8300 x118 | F +1 951-256-8321 pdiep@eibach.com"
2010 BMW M3 Coupe Alpine White - DCT |
12-22-2009, 02:46 AM | #2 | |
Moderator
673
Rep 4,737
When lowering 0.8" at the front, the bumpstop WILL MAKE CONTACT. See pictures below where I measured the suspension travel to be around 0.75" before making contact with the bumpstop. The actual suspension travel before bumpstop contact may be <0.75" (perhaps as low as 0.5" per Dinan) as my wheels are fully turned to the left, which raises the suspension slightly. |
12-22-2009, 03:13 AM | #3 | |
Let's Race
Rep 51
I thought by asking Eibach I would be able to get the answer I'm looking for but I guess it is never that easy. Thanks...
12-22-2009, 03:18 AM | #4 |
yodog
197
Rep 5,025
Everyone that has eibachs say they could not be happier with the performance. What are the negative effects of hitting the bumpstops?
12-22-2009, 03:49 AM | #5 |
Rep 566
I thought modern suspension is designed to work with bump stop contact, progressive bump stops that contribute somewhat to the overall spring rate with sway bars included. But I am a dummy for proper amount of suspension travel, so I suspect that total suspension travel will be decreased as rldzhao have suggested unless a proper length strut is fitted with the shorter spring. If ohlin comes out an adjustable shorter strut, then our world would be perfect.
12-22-2009, 04:07 AM | #6 |
yodog
197
Rep 5,025
Yeah imagine is a quality shock company comes out with an EDC replacement shock that's designed to work with a certain spring (H&R, Eibach, RDSport) and at a reasonable price. That company would make bank!
12-22-2009, 06:25 AM | #7 | |
One mod leads to another ...
416
Rep 2,900
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
12-22-2009, 07:11 AM | #8 |
8 tracks of madness
62
Rep 2,735
From my conversations with Eibach about the same question I was told that Eibach, on cars with progressive rate bumpstops, that the "spring rate" of the bumpstop is taken in to account when they design the new springs so they work as a package and that if you cut the bumpstop the total spring rate will be significantly lower than spec'd.
12-22-2009, 08:44 AM | #9 |
Rep 1,139
my mechanic trimmed my bumpstops for my eibach springs...I was gonna use the e36 bumpstops but I couldnt get them in time...So far no problems w/bottoming out and dips...
12-22-2009, 11:53 AM | #12 | |
Moderator
673
Rep 4,737
1) get a E30/6 M3 bumpstop that is shorter than E92 2) modify your upper guidesupport to be slightly shorter 3) less aggressive drop Let me just explain what happens when the car is constantly riding on the bumpstop. Our front springs have a rate of about 160 lbm (pound mass) per inch of compression. So for every inch you compress, you need an additional 160 lbm. Now, let's look at bumpstops. A bumpstop is another spring. On modern cars it selectively adds stiffness to the suspension. Our bumpstops are about 2.375" long, and 2" in diameter. Below you will see a similar, though not exactly the same, bumpstop force vs. displacement graph. You will notice that the curve is relatively flat initially, but shoots up when the bumpstop is compressed by just over 1" (25.4 mm). On a stock car, there is still about 0.75" of travel before the bumpstop is compressed, and you get another 1" or so before the bumpstop force starts to shoot up and add significant stiffness to the suspension. However, on a lowered car, let's say Eibach, you will already be riding on them, so you only get 1" or so of travel before the suspension becomes extremely stiff. This also reduces the amount of total (compression) travel allowed at the front wheels. |
12-22-2009, 01:47 PM | #13 | |
Let's Race
Rep 51
I would assume that this is what Dinan is doing with their package? Thank you for the explanation...
12-22-2009, 02:00 PM | #14 |
Rep 6,125
Yes- Dinan did it same way to all M3s (E90/92/93) and added rear spacer and modified rear spring pockets on E90 and E93s (rear heavy M3s).
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
12-22-2009, 02:53 PM | #16 | |
Rep 2,279
'09 Interlagos Blue E92 M3 (sold to a good home)
12-22-2009, 10:39 PM | #18 |
Moderator
673
Rep 4,737
Just to sum things up w/o a prolonged discussion:
1. I have never driven or ridden in an Eibach-equipped car, so I cannot comment on whether the ride or so-called performance (however this is actually measured) is better or worse than stock. I have been merely stating facts about what happens when a car is lowered using springs w/o changing anything else. 2. But having owned both H&R (-1" front) and Dinan (-0.5" front but maintains factory suspension travel), I can share my observations for both. The H&R felt fine on smooth roads, but when I drove over slightly bigger bumps on the road, the suspension would often reach the limit of compression travel and make a somewhat hard contact with the chassis. I remember pming a fellow member and telling him that the car chassis felt "upset" when going over slightly rough roads. Dinan on the other hand felt nearly the same as factory suspension in terms of the ride and comfort. I really do not have more comments except to say that it feels just like stock, except your car is now lowered by 0.5". 3. Now the million dollar question: which offers better performance? Well, it depends on what performance means to you. In terms of the 'ride', I definitely feel that the Dinan kit is more tamed, feeling the same as stock and not rough over bumps. How about 'handling'? Well, I cannot give an answer, as no one (i think) has tested/experimented these systems back to back in a controlled situation and judge the difference in handling, control, and lap times of different set ups. Neither do we have enough technical information to conduct a thorough analysis... Hope this helps. |
12-22-2009, 11:24 PM | #19 |
8 tracks of madness
62
Rep 2,735
12-24-2009, 04:34 AM | #20 |
yodog
197
Rep 5,025
So Eibach springs +e36 bumpstops is a win? Where do we purchase e36 bumpstops?
12-24-2009, 07:03 AM | #21 |
Rep 142
Curious as well.. received my Eibach's a couple weeks ago along with my MS Spacers and MS filter! Too bad the weather in CT sucks! In the meantime.. I guess I will order the bumpstops. Anyone know the price on these?
E90 M3 | Jerez Black | Black Novillo | Carbon | All options but sun shades
Mods: Gintani CB | Dinan Intake | Evo Pulley | HRE P40's | Eibach Springs | MS spacers | Matte grills | GP Thunder 7500 | Venture Clear bra |
12-24-2009, 10:31 AM | #22 | |
Rep 1,139
They r inexpensive...Like 20-30 bucks for the fronts....I think you may need something else as well b/c ur a sedan...e92s only need front ones but verts and sedans need a few extra parts I believe |
