09-30-2014, 10:19 PM | #1 |
Rep 957
FS: Alcon Superkit 384mm 6-pot + 4-pot
Looking to sell my Alcon Superkit. Calipers type 6 pots monoblock / 4 pots monoblock Discs size 384x34 mm front ; 370x30 mm rear Made In UK - United Kingdom More info here: http://www.jdl-brakes.com/alcon-supe...mw-m3-e92.html This is the biggest kit for M3 - 384 front rotors and massive calipers. Very solid build, excellent pedal feel and is one of the few kits that does not squeal with most track pads on the street (e.g., RS29 are silent). The kit is 3 years old, about 30K miles. Completely working - no leaks, no stuck pistons, no damage of any kind. The finish (black gloss) has no damage but minor color fade from temperature. Front rotor rings & mounting hardware need replacement due to wear (just the friction rings, which normally run $800-$900) and rear rotors have about 50% left. Pads included are Pagid RS-29 - 2/3 material left. Also have street pads with a little bit of material left (about 20%-25%) - could work for 6-12 month of street use easily, because the pads are humongous, bigger than in my GT3. Or you can just keep them as spare set just in case there is a pinch. The kit also includes Teflon-coated steel brake lines. Pictures below: Last edited by MaxL; 03-14-2015 at 08:03 PM.. |
10-01-2014, 10:06 PM | #6 |
Admiral
930
Rep 3,886
These MIGHT fit 18" APEX EC7's I know they clear 380mm
