      05-25-2018, 12:36 AM   #1
pcohen15
pcohen15's Avatar
380
Drives: 2013 F10 M5, Singapore Gray
Just the stain or the entire hood?
Two weeks ago, I clayed the hood of my E92, used Chemical Guys' Scratch and Swirl Remover, then applied P21s carnauba paste wax. Tonight I noticed a faint stain from a bird dropping just above the Roundel on the hood. It's about 6 inches long. I thought I got it all out, but from a different angle I saw that some if it was still there.
I'm going to polish the stain with a more aggressive polish like CG V36, then V34 or V32 if I need more cut. Using a TORQ FX10 DAP.
Question for you all: what would you do? Just polish the area where the stain is, or do the entire hood? Other than the stain, the rest of the hood is flawless (as much as it could be for a daily). It's also dirty, as you can see in the image below.
And would you mask off the area to be polished so as to control the work, or not?
Thanks for the advice.
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
      05-29-2018, 11:02 AM   #2
Ngilbe36
Ngilbe36's Avatar
Drives: 2011 E90 M3, 2019 F150
2011 BMW E90 M3  [0.00]
If this "stain" is just from bird droppings, you should be able to get it out with a very light polish, I would strip the entire hood and polish the whole thing while focusing on that spot. After the spot is out, make sure that the entire hood looks the same and you can't see that one spot was polished more than the rest. Then use whatever protection you prefer. If you are parking outside under birds with acidic droppings, Id go for a coating or sealant over a wax FWIW.
Good luck
      05-30-2018, 01:19 AM   #3
pcohen15
pcohen15's Avatar
380
Good luck
Thanks for the advice about a sealant. Do you recommend one over another?
      05-30-2018, 07:28 AM   #4
Ngilbe36
Ngilbe36's Avatar
I have used a few different kinds, my two favorites that I have tried are AMMO Skin and Wolfgang Deep Gloss Paint Sealant 3.0. There are many reviews out there with some technical data as well "Forensic Detailing" has a lot of in depth videos on Youtube depending on how far down the rabbit hole you want to go.
      05-30-2018, 01:11 PM   #5
dparm
Stop the hate, get a V8
dparm's Avatar
I would try claying the spot again. Can you feel the stain on the paint?
Past: 2011.5 M3 sedan ZCP
      05-30-2018, 01:13 PM   #6
BayE30
Drives: 2011.75 E90 M3 ZCP
definately dont mask off the area you are polishing, this can lead to hard lines in the paint...
      05-31-2018, 11:29 AM   #7
pcohen15
pcohen15's Avatar
380
I'll check to see if I can feel the stain after I wash the car. I'm guessing "no" since I didn't notice it until the light hit the hood in a certain way. From many angles, you can't notice it.
Good checkpoint, though. I certainly want to proceed in baby steps since the hood was wet sanded when I bought the car.
      05-31-2018, 11:31 AM   #8
pcohen15
pcohen15's Avatar
380
That was my suspicion. Thanks for the feedback.
      05-31-2018, 03:36 PM   #9
dparm
dparm's Avatar
A trick I learned years ago was to put your hand inside a Ziploc bag and then run it over the surface. That will "magnify" any imperfections or edges.
Hopefully the stain did not etch the clearcoat.
      07-26-2018, 12:26 AM   #10
Mterested
Mterested's Avatar
Drives: '09 E92 M3
Personally, I would strip off the protection and correct the entire panel before adding a high quality sealant or coating of your choice. If you're planning to clay and your hood is currently "flawless", expect that the clay will create some marring or light scratches.
      07-26-2018, 01:34 AM   #11
pcohen15
pcohen15's Avatar
380
Thanks for the suggestion. I removed the stain using a light polish and it looks like it never happened.
