  TireRack
      10-04-2018, 08:04 AM   #1
zhan28
zhan28's Avatar
Drives: 2010 M3 sedan 6MT
Wheel fitment question
Hey guys, so I have a set of forgestar SDC that I had on my f80 m3. Fitment is as follows:
Front 19x9.5 ET +20
Rear 19x11 ET +40
What are the chances that these will fit my e92 m3 with ZCP? Other option would be to sell these and use money for different set I guess. Thanks for the help!
      10-04-2018, 01:17 PM   #2
slicer
slicer's Avatar
2738
Front is good (depending on tire size). Rear would fit with 10mm to 15mm spacer depending on tire size.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      10-04-2018, 02:06 PM   #3
Iyzmi
Drives: E92 M3 6MT ESS625
If the fronts are SDC, they will hit the brake calipers according to Forgestar. 19x9.5 SDC needs to be +13 to clear up front. 19x10 SDC needs to be +20. You *might* be able to get away with a 5mm spacer and it will be very tight.
As slicer said, the rears will also need a spacer.
      10-04-2018, 04:53 PM   #4
slicer
slicer's Avatar
2738
Wow, they don't even clear factory e92 M3 brakes?? That's odd. I would think F80 brakes/calipers would be harder to fit than e92 single pistons.
'23 X7
      10-04-2018, 05:00 PM   #5
Iyzmi
Yup. I initially tried to order 19x9.5 +22 and Forgestar rejected the order. My 19x10 +20s come very close to the brake caliper. Maybe 1-2mm of clearance.
      10-04-2018, 07:02 PM   #6
zhan28
zhan28's Avatar
Thanks guys. They are the SDC's. I guess I'll try 5mm front and 12mm back to see how that works.
For the front, I'm assuming I might rub on the outside? Might try pulling the front pins to get a little more camber.
