10-01-2018, 11:06 AM | #1 |
Rep 1,036
Continental Extreme Contact Sport (ECS) for 18x9.5 / 18x10.5 TE37SL
Hi all,
I am considering the Continental ECS for my 18" staggered TE37SL, but I am having trouble with the rear tire size. Ideally I would run 265/35/18 and 285/35/18, but Continental only makes a 285/30/18 (too short). The only other option would be a 265 or 275/35/18 & 295/35/18 combo which might rub. Questions: Would I have an issue with the 295/35/18 in the rear? - If yes, should I run a 265/35/18 or 275/35/18 front tire? Would I be ok running a shorter rear tire (285/30/18)? Should I stick to the tried and true MPS4S in 265/285? I believe the offsets are 18x9.5" ET22 and 18x10.5" ET20. My car is on stock EDC dampers with Swift Spec-R springs. Stock-ish spec alignment, street car only.
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
10-01-2018, 11:10 AM | #2 |
Rep 5,483
295 ought to be fine. I ran the 295/35-18 Conti DW on 18x10 ET25's with stock springs for a while, not even close to hitting anything in back. The 10.5 ET20 is about 12mm closer to hitting the fender but I'd still think it'd be ok
That said, having run both, I'd just get the PS4S if you want maximum stick from a truly streetable, friendly daily tire. The fastest M3 at One Lap of America this year ran 18x10.5's with 285/30-18's all around. It's fine. Your speedo will be off a bit more than stock, and you'll have shorter final drive gearing, but it's not like it's going to cause a huge handling issue
s14_kev367.00 |
10-01-2018, 11:16 AM | #3 | |
Rep 1,036
And yes I know that the MPS4S are the benchmark, just considering these as they are slightly cheaper. I'm not sure it's worth the savings though.
10-01-2018, 12:14 PM | #4 |
Rep 5,483
Yes. That's a less aggressive setup than an 18x10 ET25 with 275/35-18 that literally every single person in the world is running on the front for track days
10-02-2018, 10:35 PM | #5 |
Save the manuals!
6015
Rep 6,745
Should be fine https://www.willtheyfit.com/index.ph...0-5&offset2=22
For reference I am at 10" wide ET10 in the rear with a 285 tire. I'm on H&R Sport Plus springs and I don't rub. Your fitment will sit 5.7mm more inwards, giving even more clearance. Now this sounds epic.
10-08-2018, 12:17 AM | #6 |
Rep 9,032
The Conti's are supposed to be slightly narrower with more rounded shoulders too.
10-08-2018, 06:48 AM | #7 |
Rep 1,036
Thanks for the responses. I ended up going with MPS4S in 265/35 and 285/35
