11-26-2011, 08:56 AM | #1 |
Rep 456
Drives: 2010 e92 M3
Apex Track wheels.... Picture request.
So many of you have bought the different colors of Apex Track wheels. I think it'd be nice to get one thread dedicated to all the different set up you guys are running. Im still curious to see if I should pull the trigger on these wheels.
Basically Im asking you to... Please Post pictures, color, size, and tire size of your Apex Track wheels. Thanks! |
11-26-2011, 11:19 AM | #2 |
Rep 8,075
Drives: 11 E90 M3 Individual
Details on the setups here... http://www.m3post.com/forums/showthr...=473321&page=2 ...the track bug getting to you? The most common setup I've seen is 18x10 w/ 275/35R18s at all 4 corners. Or 18x9.5/18x10.5 with 265/35R19 and 285/35R18. I would stick with the 18x10 square setup if want to use these for the track. When you eventually move up to R-Comps, 275/35R18's are easy to find. There's a good selection and JPJP usually stocks scrubs in this size. Hopefully I'll get tires for my set of anthracite 18x10s soon! BTW, not sure if you noticed, I had the 17x9 ARC8s on my E46 at TWS.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue Last edited by bigjae1976; 11-26-2011 at 11:29 AM.. |
11-26-2011, 03:22 PM | #3 |
Rep 456
Drives: 2010 e92 M3
No, no bug bit me.... Ive been whining about grip for a long time. And since PS2s are great daily tires... why change them. Best bet is to have a set of track dedicated wheel and tire.
Anyone running 18x10f and 18x10.5r? maybe a 275/35/18f and 295/35/18r? |
11-26-2011, 07:28 PM | #5 | |
Rep 8,075
I've done a lot of research on wheel/tire combo's...months of thinking about my setup. What I've found is if you do go with R-Comps eventually, I don't think you'll find many 295/35R18 options. The issue you may run into with the 10.5" and 295 rear is if you run R-Comps or some extreme performance summer tires...might rub. I would like to get some more rear end grip with a wider rear tire but you run into limitations if you step up to R-Comps. I like the ability to rotate my tires on my E46, you get a lot more life out of them. On the E9X, I've seen most tracked cars with a lot of wear on the outer edges of the front tires. So I think a square setup will drastically cut down on tire costs. If you plan to run street tires for a long time...then I think 275/295 is what Paintpro recommends. I think those are the tire widths that Dinan runs on their 19" setup. I've ended up deciding to use my ARC8s on the street and 4 rear OEM 18" wheels for the track. Both setups with 275/35R18s. Whenever Apex comes out with a new wheel and if I like it, I will swap out the OEM 18s.
11-26-2011, 08:04 PM | #6 |
drop a gear and...
79
Rep 967
Maybe..
I went 9.5/10.5 with 295's in the back mainly due to the supercharger. For N/A I vote for 18x10 square 275's
11-26-2011, 10:52 PM | #7 |
Rep 456
Drives: 2010 e92 M3
4Sevens, thanks so much for posting.
BigJae, disapr does have his motivating words. But Im had a mod bug since I could remember. He just throws fuel on that fire haha. disapr, I dont know. I would still like to at least do 18x10f with 275/35 and 18x10.5 with 285/35 to keep a bit more rear traction. But 275/35 isnt bad. Just trying to figure out max traction for the set up. Itd be nice if others posted pictures and set ups too. |
11-26-2011, 11:53 PM | #8 |
Rep 8,075
I think most stick with Apex's recommended setups which shouldn't be much different with other brands of wheels as well.
The first post of this link has some pics for you Square Setup 18x9.5" Front & Rear with 275/35/18 18x10" Front & Rear with 275/35/18 - Preferred setup Staggered Setups 18x9.5" Front 265/35/18 - 18x10/10.5" Rear 275/35/18 18x9.5" Front 265/35/18 - 18x10/10.5" Rear 285/35/18 or 285/30/18 18x9.5" Front 275/35/18 - 18x10/10.5" Rear 285/35/18 18x9.5" Front 265/35/18 - 18x10.5" Rear 295/30/18 or 295/35/18 18x9.5" Front 275/35/18 - 18x10.5" Rear 295/35/18 18x10" Front 275/35/18 - 18x10/10.5" Rear 285/35/18 Rear 18x10" Front 275/35/18 - 18x10.5" Rear 295/35/18 – Preferred setup
11-27-2011, 12:10 AM | #9 |
Rep 16,214
Drives: 2011 E92 M3
i have 2 sets of apex, love them. wheel size 10 and 10.5. tire sizes are 275/35/18 rs3 and 285/35/18 rs3.
stock car
11-27-2011, 02:59 PM | #10 |
Rep 456
Drives: 2010 e92 M3
wow pakman, real nice pictures! Thats basically the size wheel and tire Id like to run. Does it feel pretty neutral?
EDIT: What lip you running!? It looks great! |
11-27-2011, 07:44 PM | #11 | |
Rep 16,214
Drives: 2011 E92 M3
the jl motoring gts cf lip
stock car
11-28-2011, 08:00 AM | #12 |
Rep 456
Drives: 2010 e92 M3
awesome! I love it when Mods move a post for no dumb reason especially considering I wanted to SEE ( cough cough, gallery ) wheels on the track. Now less people will see this thread.
11-30-2011, 10:27 PM | #13 |
Rep 160
you probably saw this:
http://www.m3post.com/forums/showthr...highlight=apex I like these wheels but I have to say that I bent one putting it slightly off track in a manner in which I like to think a really strong wheel would not have gotten bent. it was repairable and I still think they are good value for money, but.... still running 18x10 but 265 front 295 rears. you can still rotate the car with this setup. |
11-30-2011, 10:37 PM | #14 |
Bored at work....
890
Rep 5,391
I'll have my pics up in spring.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
12-01-2011, 11:26 AM | #15 |
Rep 456
Drives: 2010 e92 M3
I bought a set from Pakman so I'll have my own pictures up after the 11th of December. The set up I bought is an 18x10f and 18x10.5r with 275f and 285r. I can't wait to try out some more grip. I'm sure it won't be an insane difference but enough to make it count.
"Out of pure habit, I gave a black M3 a point by on the way home from work this evening." - ThunderMoose
12-02-2011, 02:38 PM | #17 | |
Rep 722
Just took delivery of my 18x9.5 and 18x10.5 Apex wheels today. |
12-02-2011, 06:07 PM | #18 |
Rep 8,075
I love the no nonsense mild concave design with the straight spokes! Not too much, not too little...but just right! No stepped, deep dish, track spec, and 100 piece with gold fastener silliness.
12-03-2011, 12:54 AM | #19 |
Rep 722
12-04-2011, 07:36 PM | #20 |
Rep 456
Drives: 2010 e92 M3
Thats Awesome Daniel, Cant wait for next weekend! It'll be intense!
12-05-2011, 06:13 AM | #21 |
Rep 8,075
These wheels are quite popular. I saw a 1M and a E90 M3 this weekend in Cresson with the ARC8s.
12-05-2011, 09:18 PM | #22 |
Rep 938
they are great rims. look even better with studs instead of the silly bolts. i did put a coat of wax on them, it makes wiping them down much easier. odds are i added a hint of sheen, but the brake dust and tire marbles cover it just fine.
