Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > USA - Southwest
BPM
      11-04-2017, 07:53 PM   #1
whats77inaname
Drives: when at all possible
FS: 19" Volk TE37 Time Attacks w/Toyo Proxes R888 w/TPMS - $3200
Moving along with my part out, I'm selling my Volk TE-37 Time Attacks w/2008 TPMS and Toyo Proxes R888 tires. They are currently sitting in a climate controlled storage unit and will be until sold.
Wheels:
Fronts: 19x8.5 offset +30
Rears: 19x10.5 offset +25
Tires:
Front: 265/30/19 (they have less than 1000 miles)
Rear: 295/30/19 (they have about 3000 miles)
Time Attacks have center caps that other TE-37 don't. I acquired 10 of them and had them all anodized blue in the event I ever lost any of them. I separated the center trim rings, and had 6 of them blasted and primed, and then painted Alpine White, just like my car. The other 4 are still the OEM gold color. The center caps are aluminum, and by themselves are worth over $700 (https://www.ebay.com/itm/322521594644).
The wheels were stripped down, and powder coated with a triple powder coat: silver, gun metal, and then an automotive clear. They've held up for a number of years, but there are a 5 spots on 1 wheel where the powder is flaked off, and 1 on one wheel. There is a rub on one of the rear wheels about 7". I wouldn't call it a curb, b/c there isn't any metal damage.
Each wheel has the correct hub-centric ring (aluminum) so that they fit on the oem rotors w/no gap.
In the pics below, the top pic shows the rear tread indicator, whereas the bottom shows the front tread indicator. The tires have never been repaired.
The setup comes with pre-LCI TPMS sensors (installed), as well as a set of LCI TPMS sensors (not installed.)
These wheels sell for more than $600/each. The barrels are straight, the wheels are true. For all intents and purposes, with the value of the wheels and center caps, you're practically getting the tires for free. I'm looking for $3200 for everything. I'm in Austin. You can check my iTrader.
I used Macht Schnell 10mm spacers up front, nothing in the back (as I'm dropped a bit.) No, they didn't rub.
History: http://www.m3post.com/forums/showpos...&postcount=337
      08-29-2018, 01:21 PM   #2
whats77inaname
Up.
      08-29-2018, 01:45 PM   #3
E46NYBMW
Drives: E46 M3
Have a pic of these mounted?
      08-29-2018, 05:35 PM   #4
whats77inaname
Yup
BrewRifle419.50
      08-30-2018, 01:31 PM   #5
javistor
javistor's Avatar
Drives: 2008 E92 M3
Bump for a solid guy and awesome wheels!
BrewRifle419.50
