01-18-2021, 07:10 PM | #1 |
Rep 99
S65 engine differences
I tried searching but didn't see completely conclusive. I'm looking to swap an s65 into my car that has a blown engine. I'm looking at a couple of different options and wanted to clarify before making a decision. I currently have an 08 manual. My question is are all s65 engines swappable into my car? Any differences in model years that I need to account for? Any differences in the chassis it's coming from (90, 92, 93)? Lastly, does it matter what transmission the engine was mated with? Thanks.
01-19-2021, 06:00 AM | #3 |
mTekMods
2139
Rep 2,898
All the same, altho a dct engine is gonna have a different hose on the rear coolant crossover pipe, youll have to replace that with your manual part.
01-20-2021, 09:54 AM | #5 |
Rep 7,109
This is the coolant/oil exchanger on the DCT you refer to? Other then for pre heating the DCT, any experience that a failing aux pump would create over heat in the DCT? I'm thinking at stand still without support from the air/oil exchanger, this at least helps keeping the DCT fluid down to 100C.
01-20-2021, 12:00 PM | #6 | |
mTekMods
2139
Rep 2,898
Also, operating temp on the coolant for my car is usually about 215-220*F, when driving aggressively the temperature rises rapidly on coolant, I have considered removing this before and letting the transmission utltilize soley the oil cooler circuit but I am not sure of any consequences with warmup of the gearbox. Having the heat exchanger is why the gearbox temperature rises when starting at idle so I am sure it serves a purpose.
01-20-2021, 01:57 PM | #7 | |
Rep 7,109
01-20-2021, 10:00 PM | #9 |
Rep 2,138
Drives: 2011 E92 M3
Not guaranteed. My 2011 had copper bearings.
01-20-2021, 10:06 PM | #10 |
Rep 2,747
A couple of accessory changes are Lines and Oil cooler on 08's changed around May production iirc. Power steering pump and belt routing also changed at the same time. Shouldn't effect a swap if you keep your original accessories on either item.
9ers
01-21-2021, 05:04 AM | #11 |
mTekMods
2139
Rep 2,898
Possible since both cooling systems do interact.
01-21-2021, 04:04 PM | #12 |
NooB
381
Rep 383
01-21-2021, 06:32 PM | #13 |
mTekMods
2139
Rep 2,898
01-21-2021, 07:15 PM | #14 |
NooB
381
Rep 383
