01-16-2021, 08:41 PM | #1 |
Rep 109
Help...Stripped oil pan
So was doing an oil change today and had a dreadful moment when loosening the oil pan bolt on the rear sump.
So yup my oil pan is stripped. Turned out to be a positive since this is pretty much forcing me to get my rod bearings taken care of as well. Planning to take it to MRF on wednesday but need some help on what to do until then. My car is currently on my quickjack with no oil and Im planning on towing it to MRF. Should I fill the car up w fresh oil? So that I can still move my car to the driveway and freely put it in neutral for the tow. |
01-16-2021, 08:54 PM | #3 |
Rep 109
01-16-2021, 09:53 PM | #6 |
Rep 109
01-17-2021, 02:42 PM | #7 | |
Rep 865
The flatbed driver will cinch the car down with straps. When you get it to the shop, they are going to need it to be in neutral as well, ...and tape a note to the steering wheel that says "NO OIL! DO NOT START ENGINE!!!l"
Chris, 2008 E92 |
01-17-2021, 10:12 PM | #8 |
Rep 159
Do as you will, but if it was me I'd at least put one of those "rubber expansion plugs" in it and put some oil in, just in case someone, somewhere, somehow hits the wrong button..., You can purchase oversized self-tapping drain plugs, but that would depend on whether and how you expect to repair the pan. There are also repair methods available for installing helicoils, time-serts, etc.
Davisca4552207.50 |
01-18-2021, 12:06 AM | #9 | |
Rep 109
Davisca4552207.50 |
01-18-2021, 08:43 AM | #10 |
Rep 684
I would put the note on the wheel and disconnect the battery. worse case the note falls off and they start the car. or just dump the old oil back in (after you filter it of course). they're only gonna drive it on and off the truck.
Davisca4552207.50 |
01-21-2021, 09:46 AM | #11 | |
Rep 422
2011 M3 Sedan
2001 M Coupe 2020 Macan Turbo 2018 GT3 |
01-21-2021, 10:03 AM | #12 |
Rep 702
Davisca4552207.50 Space Fox1042.00 |
01-28-2021, 05:39 PM | #13 | ||
Rep 392
Drives: F13 M6
02-16-2021, 09:32 AM | #15 | |
Rep 865
Get it on and off the tow truck ok? And, out of morbid curiosity, how'd the old rod bearings look?
Chris, 2008 E92 |
02-16-2021, 09:48 AM | #16 | ||
Rep 109
Luckily, MRF took good care of it providing 2 oil flushes free of charge. Malek said internals are fine and look extremely well taken care of. I'll attach a pic of my bearings |
02-16-2021, 09:58 AM | #17 | |||
Rep 865
Chris, 2008 E92 |
SAMM3Y3085.00 |
02-16-2021, 12:56 PM | #18 | |
Rep 2,138
Drives: 2011 E92 M3
It is likely fine. Engines at idle produce very minimal stresses on rotating parts. We used to do "MotorBlast" fundraisers in engineering. Drain the oil and coolant, start the pig, bring the revs to ~3000-4000RPM and start a timer. Damn things would last minutes. Whoever bet closest to the time won the 50/50. I would still nut punch the tow truck driver just cause. Cheers,
Space Fox1042.00 Davisca4552207.50 |
02-16-2021, 02:05 PM | #19 | ||||
Rep 109
02-16-2021, 02:10 PM | #20 | ||
Rep 109
Was pissed but Malek did assure me everythings fine and no damage so Im over it. I did however file a claim w/ AAA and im letting that play out. |
02-16-2021, 03:08 PM | #21 |
Rep 3,988
wow
hopefully nothing happens to the motor down the road.
02-16-2021, 05:02 PM | #22 | |||
Rep 865
Because if he did, I'm with Sharbag, that person is owed a serious...something bad. I don't know exactly what, but something really, really painful.
Chris, 2008 E92 |
Scharbag2620.50 |
