02-28-2024, 06:39 PM | #1 |
Rep 5,548
E9x M3 Dyno Curve?
I came across this e9x M3 dyno curve on a forum vendor’s website. It was used to define peak hp and torque values as well as typical gains across the rpm band from a S65 ECU tune being sold by this vendor.
Peak Power: 20 whp @ 8300 rpm Peak Torque: 20 lbf-ft (not specified) Typical gains (copied directly from the website): 25hp @ 5000-6500rpm, 20lb.ft @ 4000-6000rpm Do you see any issues with this before-after e9x M3 dyno comparison plot? Crap - resolution is too low (fixed) Last edited by M3SQRD; 02-29-2024 at 04:36 AM.. |
02-28-2024, 07:41 PM | #2 |
Rep 1,614
Without the X-axis, it's hard to tell if anything is wrong with it. The X-axis doesn't always have to be RPM, sometimes in can be speed. If the X-axis were speed, and the runs were in two different gears, then nothing is wrong (other than running in two different gears). If the X-axis is RPM, then yes, there are some obvious problems like the baseline not being a full run to max RPM. But without the X-axis, you can't really tell much.
DrFerry6728.50 |
02-28-2024, 07:47 PM | #3 | |
Rep 5,548
02-28-2024, 07:52 PM | #4 | |
Rep 5,548
02-28-2024, 08:10 PM | #5 |
Rep 1,614
It mostly looks normal now that we can see it in context. HP=TQ at 5252 right where it should. The tuned clearly had the RPM limiter raised. Even the numbers are right in line with the s65dynos.com database. The only thing I see is that the stock pull didn't got above 7900/8000 RPMs.
DrFerry6728.50 |
02-28-2024, 08:13 PM | #6 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
///M Power-Belgium63392.50 |
02-28-2024, 08:17 PM | #7 | |
Rep 5,548
02-28-2024, 08:21 PM | #8 | |
Rep 5,548
02-29-2024, 07:07 PM | #10 |
Rep 5,548
Really? I haven’t seen a s65 torque curve that has a double hump at low rpm and then starts to drop off at 4.5k rpm. I’m used to seeing torque curves that look similar to the ones below. Also, it’s odd no additional power/torque developed in a tune until around at 4.5-5k.
