08-06-2022, 02:39 AM | #1 |
Rep 222
Squirmy E90
My E90 has behaved squirmy for a while with a setup consisting of ZCP wheels with stock size brand new SportContact 7 tires, 12mm spacers in the front, 10mm spacers in the back, stock shocks with Eibach lowering springs, fresh wheel alignment (attached but in Swedish). Bushings have been checked. I'm suspecting the stock shocks and Eibach springs combo. Any ideas are appreciated.
2010 E90 M3
2013 F31 328i Touring M Performance |
08-06-2022, 03:20 AM | #2 |
Rep 1,692
IF i am reading this right, excuse me if I am not had to use my brain for a bit..
you have TOE OUT, on the rear? that would be it..
08-06-2022, 08:27 AM | #3 |
Rep 222
Yes, total toe rear +1.3mm and individual left +0.6mm and right +0.6mm
2010 E90 M3
08-06-2022, 05:01 PM | #5 |
Rep 222
So you guys are saying that the right way forward is to dial in some total toe in (negative) of -1.6mm (-1/16") and leave the rest as is both front and rear?
2010 E90 M3
Bimmer Barney1250.00 |
08-06-2022, 05:13 PM | #6 |
Rep 4,160
You cannot have toe out in the rear. Car will oversteer easily on corner exit. You need a bit of rear toe-in.
Front should be zero toe. I don't think this car needs front toe-out. Last edited by Redd; 08-07-2022 at 03:29 AM.. |
08-07-2022, 03:00 AM | #7 | |
Rep 1,692
toe-out will cause oversteer on corner exit and straight-line stability. up to 1/16th (1.6mm) total, toe-in would be ideal for a street car. leave the front neutral at 0..
08-08-2022, 03:21 PM | #8 | ||
Rep 222
2010 E90 M3
01-02-2023, 10:25 AM | #11 |
Rep 222
Reviving my own old thread. I never got this sorted before parking the car away for the season so it is still not handling properly.
Sorry, but isn’t toe in measured in positive value? I remember the alignment guy saying something like that….. Also found this: https://help.summitracing.com/app/an...what-is-toe%3F Attracted is the alignment sheet after a 2nd alignment was done.
2010 E90 M3
07-05-2023, 12:43 AM | #12 |
Rep 222
Installed Bilstein B8's, H&R swaybars and ZCP wheels with Conti SportContact 7 in stock size with 10mm spacers front and rear and the car is still squirmy.
Attaching the recent wheel alignment. It is in Swedish language and the rear axle comes first and with final specs in the far right column. What the hell is wrong? The Conti's cannot be that bad!
2010 E90 M3
07-05-2023, 05:28 AM | #14 |
Rep 222
Straight line when giving steering input and under braking at high speed.
2010 E90 M3
07-05-2023, 05:35 AM | #15 |
Rep 222
I was thinking to give it a go with the following alignment specs.
Front: Camber: Maintain current alt. slightly more negative if achievable (-1°45’ +/-0°15’) Toe in/out: 0 (neutral) Rear: Camber: Maintain current alt. slightly more negative if achievable (-1°45’ +/-0°15’) Toe In: 0.15° to 0.20° per side Total Toe In: 0.25° – 0.40° Any thoughts on that?
2010 E90 M3
07-05-2023, 05:57 AM | #16 |
Rep 4,160
High speed hard braking with steering input is squirmy for any car lol. I don't think it's a car problem. My car hard braking at track with steering wheel perfectly straight the rear still feels like it wants to step out. Many cars do that, including high performance cars. You just need to learn to drive around it. Front monoballs, solid subframe and rear spherical conversion help somewhat but won't totally eliminate it.
07-05-2023, 06:15 AM | #17 | |
Rep 222
I come from a history of over 30years with multiple high performance cars incl. rear engine cars as well as daily drivers with sporty character and none of them has handled this poorly. Even my daily driver F31 328 handles better than this M3! My friend's E93 M3 also handles better! So NO, it is not normal/acceptable.
2010 E90 M3
07-05-2023, 07:00 AM | #18 |
Rep 4,160
Hmm if you say an E93 M3 handles better then it doesn't sound normal. But not sure how to help you without driving the car. You've fixed your alignment, replaced dampers, added sway bars.
The only other thing I can think of is solid rear subframe bushings. With the rubber bushings you get the feeling like the rear end wants to go sideways when you go over ruts or bridge joints in the middle of a turn. It's not actually the tires losing grip (even though it feels like it) but more of the body moving independently of the chassis due to the rubber bushings. Changing to solid subframe bushings eliminates this and also improves chassis rigidity and feel tremendously. But it's not a simple job. |
07-05-2023, 07:04 AM | #19 |
Rep 222
While installing the new chassis components my mechanic also checked all the bushings in the rear subframe and all were found to be OK.
2010 E90 M3
07-05-2023, 09:18 AM | #20 |
Rep 4,160
Yes the bushings 'look' ok but because they are rubber and they exhibit that lateral movement that feels like tires losing grip. With all the work you've already done I suspect that is what you're experiencing now when you say 'squirmy' cos that was the same complaint I had with the car when I first got it. Maybe you can try someone's car which has had solid subframe done to see if the problem goes away.
07-05-2023, 10:19 AM | #21 |
Rep 222
I don’t know man, my mechanic is a very well seasoned race mechanic, with his own M3 collection of various models so he knows his stuff.
2010 E90 M3
