08-08-2023, 02:29 PM | #1 |
Rep 339
763 M wheels on e93
Hey everyone,
i have a 08 e93 m3 with air suspension. I just found a staggered 763m wheels. They are 20×8.5 +20 for the Front & 20×10 +35 on the rear with 265|30|20 and 305|30|20 tires. I would really appreciate if someone could advise me if this set will fit on my car. Thank you gain in advance
08-09-2023, 01:00 PM | #2 |
Dont listen to me
795
Rep 562
so here are the facts comparing the wheel sizes you listed to the M220 19" stock wheel/tires. I have never seen a factory BMW 763M front wheel size of 20x8.5 +20: can you confirm that size or are these aftermarket replica wheels?
TLDR: Wheels will fit OK, tires are too big Front:
Rear:
My opinions: Really the wheel sizes themselves will fit and can look perfect with adding some thin wheel spacers (depending on tire choice). The 265/30 and 305/30 tires are too big and is going to cause you problems in all areas. It would be best to choose a tire that has a maximum diameter of 25.8 to 26" in the front and 26.3-26.5" in the rear. For example a good fitting tire setup would be 245/30/20 and 265/30/20, although a 265mm tire on a 10" wheel looks a tiny bit stretched to me. A 275/30/20 rear tire is possible at 26.5" diameter, but you run a tiny extra risk of rubbing depending on how low your car is, road conditions, etc.
Instagram: @thatwhitem4
08-10-2023, 09:03 PM | #3 |
Army Welder
1119
Rep 470
Drives: 2008 AW E92 M3
When I bought my M3 they came with that exact fitment and they fit great.
2021 M2 MT SO
IG: von_bee_ YT: VonB |
_Mozes_e93m36.00 MineralFox0.00 |
08-11-2023, 01:39 PM | #5 | |
Dont listen to me
795
Rep 562
On a perfectly mint, stock car that is lowered, those tires should rub the liners and bumper tabs.
08-11-2023, 01:59 PM | #6 | |
Army Welder
1119
Rep 470
They rub on hard bumps and humps on the road and the front of the inner fender has some scuffs from the tires. But other than that no modifications to the inner fender or anything shaved. I only removed the wheels because I don’t like 20” wheels.
2021 M2 MT SO
MineralWhiteF80794.50 |
08-16-2023, 02:45 PM | #7 |
Rep 339
Thank you so much for the pictures. I was considering these wheels due to the lowered price locally, but i agree with you about the size. After doing more research on the forum i started to like 18" wheels also. Now just need to find the perfect fitment without using any spacers
VonB1119.00 |
08-16-2023, 02:46 PM | #8 | |
Rep 339
08-17-2023, 07:52 AM | #9 | |
Dont listen to me
795
Rep 562
Take a look at this excellent fitment article that Apex wheels did for how different wheel/tire sizes fit on the e9x m3. I think this link will give you the knowledge you need to make an informed decision on what wheel/tire sizes makes sense for your application (regardless if they are Apex wheels or a different brand wheel). https://support.apexraceparts.com/hc...-Fitment-Guide
VonB1119.00 |
