05-29-2023, 06:48 PM | #1 |
Rep 146
Rear trunk floor tray removal
For those of you guys who removed your trunk floor panel/tray, did you remove the heat shields below as well?
The piece I'm referring to is a black plastic tray that covers the hole in the trunk. Hard Motorsports makes a filler panel to replace it (link below): https://www.hardmotorsport.com/hard-...-filler-panel/ There appears to be some plastic lines (EVAP?) and a portion of the battery cable that are attached to the tray. They'll also be exposed with the heat shield removed. Would this be an issue? |
05-29-2023, 07:40 PM | #2 |
Rep 12,732
if you want to hold off for just a little bit, i might be producing a carbon panel. it might be a little more than the hard motorsport part, but it will be nicer.
the only thing attached to the plastic tray is the heat shields. they attach towards the right center with a bolt. i zip tied them together to keep some tension on them (they are also secured at the sides) and it kept the shields from drooping onto the exhuast. no new noises. the charcoal filter is its own appraratus. there are some clip-on evap hose brackets but if you retain the heat shields, they will be fine. i don't remember exactly how they were routed, but it was not an issue.
tsk941522.00 |
05-29-2023, 08:26 PM | #3 |
Rep 1,681
Is there anything special to know about removing this “apparatus”?
05-29-2023, 08:29 PM | #4 | |
Rep 146
05-29-2023, 10:06 PM | #5 | |
Rep 12,732
i the tubes might secure with some of those press-in clips, but they were pretty secure. i think i zip tied them to limit vibration.
05-29-2023, 10:32 PM | #6 |
Rep 12,732
there is probably some programming that needs to be done, but it will for sure throw a check engine light if you mess with it. looking at weight figures from parts diagrams, the filter, tubes, and plastic bracket should yield about 5lbs.
06-04-2023, 06:04 PM | #7 | |
Rep 12,732
06-11-2023, 11:46 AM | #8 |
Boost
1355
Rep 3,695
Drives: 135i M-Sport
I replaced mine with 2.5mm carbon sheet and the noise was unbearable. I liked the idea of cleaner air back there and planned to build a small diffuser to keep air from turning the rear bumper into a parachute.
The weight savings for me was in the worst place (rear) and it was only 2-3lbs I think. I also moved to Akra since then which is much quieter so I might try installing it again.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
roastbeef11589.00 |
12-07-2023, 11:18 PM | #9 | |
Rep 8,077
Drives: 11 E90 M3 Individual
2018 F30 320iX Melbourne Red
12-08-2023, 12:25 AM | #10 |
Boost
1355
Rep 3,695
Do you have suggestions for sourcing foam core sheets in 1/2 - 3/4" range? I'm planning to experiment with vacuum infusion for a custom splitter but I'm having trouble finding foam core material. Trying to avoid ordering online and having to use 2 sheets side by side alignmed parallel with the car as that'd reduce rigidity by a lot I assume (total noob).
12-08-2023, 07:10 AM | #11 | |
Rep 8,077
The core has to have holes in it or scored so air has a path to escape.
