11-10-2018, 01:59 PM | #1 |
Rep 6,734
"18 BBS Motorsport E88 - Black with Polished Lips - *NEW*
Once again I'm selling what I believe is the Holy Grail wheel for the BMW M3 - The BBS E88. I have been working with BBS for nearly 10 years and have sold numerous sets of E88's. The centers used on this set were made by BBS at my request in order to allow a 3" rear lip with 295's! I purchased this set for myself but mistakenly assumed that the new center would clear my rear Essex AP Racing brakes. Whoops! Wheel Model: BBS Motorsports E88 For those of you who aren't familiar with this wheel - They are made to order by BBS to the buyer's specification. They are a forged 3-piece wheel. This wheel is the same BBS product you see at the track in pro-level racing. Do not compare this to BBS street wheels as the Motorsports division is separate and makes bespoke products for their customers. Each component is readily available from BBS. If you damage a lip or barrel you can easily source the individual component that was damaged. This differs from BBS street wheels as you can not buy individual components from BBS. These are the real deal - Retailing for over $6k per set. Note that I am a BBS dealer and I have had numerous sets of these wheels and can advise on fitment. Size: 18 x 10 et24 (2" lips) 18 x 11 et24 (3" lips) * Fitment Notes * Front - This spec allows for 265, 275 or 285mm front tires but if you have coilovers that reduce inner clearance you will need to either use a spacer, install a shorter spring, or remove the helper spring. Rear - This spec allows for the use of 295/30/18, 285/35/18 and 295/35/18 on e92. Plus 295/35/18 (and possibly 305/35/18) on E90 Note that all of these fitments are dependent upon tire sizes, alignment settings and other factors. I will consult you on the best option for you. Style: This is the non-center cap version of the E88 (can not accept center caps). It is known as the 'open lug pocket' E88. It's personally my favorite style, providing a racey look. Most tracks do not allow center caps; this is the wheel to get for track use. Condition: NEW - only installed rear tires and test fit - not a single revolution of use. SEE PICTURES Big Brake Clearance: Fits - OE E92 M3 brakes, Brembo 365/345, Stoptech 380/355, Essex AP Racing Pro 5000 front Does NOT Fit - Essex Racing AP Pro5000 Kit (rear only - Front fits), or Brembo 380mm kits Tires: Michelin Pilot Sport Cup2 Tires available for an additional cost. Tires have 2k miles of use and 1 track day. Tread depth is 7.5/32 to 8/32 (as new) on the rear tires, same on the inside of front tires. Outer edge of front tires have more wear due to track use. 285/30/18 295/30/18 Location: Santa Barbara, CA - will ship Price - Wheels: ** SOLD! ** Black E88 by slicerM, on Flickr
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 12-26-2018 at 07:47 PM.. |
11-10-2018, 02:03 PM | #2 |
Rep 6,734
Pics from Test Fit:
Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr More Pictures: Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr Black E88 by slicerM, on Flickr BBS by slicerM, on Flickr
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 11-13-2018 at 07:25 PM.. |
11-10-2018, 04:17 PM | #4 |
Rep 6,734
Definitely
'23 X7
11-10-2018, 04:49 PM | #5 |
the doctor
284
Rep 432
I don't want to come across as being vulgar. I saw the first picture of the wheel and the first thing that came to mind was MotherFucker.
M3ANMACHINE931.00 |
11-10-2018, 05:23 PM | #6 |
Rep 1,612
11-10-2018, 05:44 PM | #7 |
Rep 6,734
Well, with a little bit of money you can see them in person every day!
'23 X7
11-10-2018, 05:45 PM | #8 |
Rep 6,734
It's only money - you can always make more.
'23 X7
jeremyuhh464.50 M3ANMACHINE931.00 |
11-10-2018, 05:58 PM | #10 |
Rep 6,734
I did not sell them. I was planning to install on my personal car but I could be convinced to sell if you are interested. They will actually be having tires mounted on them on Monday. Alternatively I can order in a set for you. PM if interested.
'23 X7
11-10-2018, 06:20 PM | #11 |
the doctor
284
Rep 432
11-10-2018, 06:21 PM | #12 |
Rep 6,734
What's another $4850??
'23 X7
11-10-2018, 06:24 PM | #13 |
Rep 6,734
Some pics of a similar spec installed in silver -
Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr Untitled by slicerM, on Flickr
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 11-10-2018 at 10:05 PM.. |
mmbv100078.00 |
11-10-2018, 08:28 PM | #14 |
Rep 1,612
MBN to be rich lmao
What stud kit is that if you don't mind me asking |
Richsocal12429.00 |
11-10-2018, 08:44 PM | #15 |
Rep 6,734
Turner Motorsport bullet nose, dry lube by MSI. 19mm zinc coated lugs from Turner as well
'23 X7
11-10-2018, 09:39 PM | #16 |
E92 M3
13
Rep 174
same! I was like shiiiiittt this man's back at it again! holy grail set of wheels for sure! I'm planning on getting a set of these in the near future too. GLWS
photography page : https://www.instagram.com/joema_autogallery/?hl=en 08 jerez black E92 / Gintani / Bimmerworld / Dinan / Active Autowerke / Advan F7 / AC Schnitzer / Varis / IND / Vorsteiner / RKP / Sabelt / Stoptech |
11-10-2018, 10:11 PM | #17 |
Rep 6,734
Thanks! Let me know when you are ready.
'23 X7
11-10-2018, 10:13 PM | #18 |
Rep 6,734
'23 X7
11-13-2018, 07:25 PM | #22 |
Rep 6,734
'23 X7
LatifE90265.00 |
