  TireRack
      12-29-2018, 09:05 PM   #1
monterey
monterey's Avatar
339
Drives: 2008 M3
will i be able to lower my car
I have square 19x10 +20 on 275/30/19 I feel the fronts poke out and i think i will get fender damage if i drop the car. anyone with these specs?
A job is nothing but work.
      12-29-2018, 09:20 PM   #2
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Try it, reshaped fender naturally.
      12-29-2018, 10:01 PM   #3
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
You can add camber
IanMan384.00
      12-29-2018, 10:12 PM   #4
roastbeef
roastbeef's Avatar
you can probably get away with a little bit, but its going to be close enough that it is going to depend on how much camber you run and what brand/model of tire.
      12-29-2018, 11:48 PM   #5
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
Yes, might need coil overs cuz that's my only reference but my car is lowered on same tire size it worked on stock camber too..
9ers
      12-30-2018, 04:13 PM   #6
SonnyJack
Drives: '09 E92 M3/'18 F83 M4
I ran 19x9.5F +20 on 275/30/19 with no problem (not your exact wheel size I know). First I did this with H&R sport springs and then with KWv3 coilovers. No rubbing in either case.
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
      12-31-2018, 12:22 PM   #7
HeavyArmZ
I currently have 19x10 +25 with 12mm spacers, 275/30/19 Hankook in front. No rubbing with Dinan springs.
      01-01-2019, 11:03 AM   #8
6ixSpd
Save the manuals!
6ixSpd's Avatar
6015
Drives: '16 M3, '23 718 Spyder
Zero issues. You're forgetting that when you lower it, the geometry changes to camber in a little bit more as well, giving you the clearance needed.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      01-02-2019, 12:48 AM   #9
monterey
monterey's Avatar
339
Drives: 2008 M3
are you running camber plates? any oics?
      01-14-2019, 05:57 PM   #10
Gfunk720
Gfunk720's Avatar
13
Drives: E92 M3- AW
2008 BMW E92 M3  [0.00]
You're fine. I'm running the same size on a 19x10 +15/f +10/r and it doesn't even rub. Front or back.
I'm lowered, but not slammed.
      01-15-2019, 08:44 AM   #11
Iyzmi
Drives: E92 M3 6MT ESS625
19x10 +20 F14 with 275/30/19 on Eibach springs is a very common setup that shouldn't rub. Check out the mod bargains F14 page and you'll find plenty of pics.
