      04-27-2019, 08:34 AM   #1
GasBurnlife(landapanda)
Drives: BMW M2
Flipping directional tires
All - looking for insight regarding flipping staggered setup. I run mainly tracks that put a lot more wear on the left set of tires. What's the consensus regarding flipping wheels on the respective axels? I run directional tires (PS4s). I imagine there may be some minor impact to drive ability due to the tread design, but generally speaking I have to think the setup won't result in any safety issues that would result in tire failure.
When I rode moto, we used to flip directional tires with no issues. I expect same results with summer performance tires.
Looking for insight from those that have tried this.
Thanks!
      04-27-2019, 09:42 AM   #2
dbyrd
DSC Off!
dbyrd's Avatar
304
Drives: 2012 E92 M3 6MT ZCP
I don't think the PS4s is a directional tire.
That said, I've run the RE71R and RS-4 in the wrong direction with zero decrease in lap times and grip. I'd advise against it in the wet though.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
      04-27-2019, 09:58 AM   #3
tsk94
tsk94's Avatar
Basically this, should be totally fine for use in the dry. In the wet they wouldn't work neither as well though.
      04-27-2019, 10:12 AM   #4
Drives: BMW M2
Appreciate the response guys. Sounds like switching the wheels won't be an issue and will save me a bunch of mullah for more track time.
      04-27-2019, 03:08 PM   #5
dparm
Stop the hate, get a V8
dparm's Avatar
My understanding is that the directionality of tires is for water evacuation. On a dry track, you probably won't notice a difference.
However, some tires do have different tread compounds in different parts of the tire to aid in handling, so you could potentially lose that benefit.
Past: 2011.5 M3 sedan ZCP
      04-30-2019, 07:39 AM   #6
bigjae1976
bigjae1976's Avatar
1570
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
I think a PS4 is an asymmetrical tire. You can't flip them on the rim but you can swap sides with them.
I'm pretty sure the PS4 has a different rubber compound across the tire which is why you can't flip them.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
SYT_Shadow11479.50
      04-30-2019, 08:49 AM   #7
dparm
dparm's Avatar
Correct, they are asymmetrical construction but not directional. This makes things easy -- just swap the entire wheel/tire on the axle. (e.g. move the passenger rear to the driver rear and vice versa)
Outer side: a novel hybrid elastomer for DRY grip
Inner side: new mix of compound with specific functional elastomers and silica provides excellent wet grip and braking
      04-30-2019, 02:18 PM   #8
M3 Number 86
Drives: black m3
i don't think direction is important on the track unless there is water.
but asymmetrical tires are meh since you can't go inside out
      04-30-2019, 02:19 PM   #9
M3 Number 86
Drives: black m3
that still means you'll always wear the outside
      04-30-2019, 03:51 PM   #10
dparm
dparm's Avatar
Correct, but tires don't wear evenly on both sides of the car, in my experience.
      04-30-2019, 08:33 PM   #11
Drives: BMW M2
Since most of the tracks I run are heavy on the right hand turns, swapping the wheels on each axle will still prove beneficial and improve tire life. Appreciate everyone's insights on this!
      05-02-2019, 09:44 AM   #12
M3 Number 86
Drives: black m3
For sure. But lasts even more when you notice all the outsides are worn after a number of events.
