      07-06-2020, 07:49 PM   #1
akkando
akkando's Avatar
5863
Failed Clear Coat?
So after washing the car I noticed on the driver side rear door handle there are these weird rough spots. Is this failed clear coat? I don't recall it looking like this when I bought it in Sept but I could have missed it as I don't inspect the rear door handle often. Either way what is this? what do I do about it? maybe do nothing?
      07-06-2020, 08:20 PM   #2
Ervin87
Ervin87's Avatar
Drives: E92 M3 | B5 S4 | E30
That handle has been repainted. If that is the only part with the issue, you can get it properly redone this time so it doesn't happen again.
      07-07-2020, 12:03 AM   #3
akkando
akkando's Avatar
5863
as far as I know. I had a detailer paint correct and coat the car and he used a paint depth gauge and showed me that it all seemed consistent.
He did say the car appeared to be in a body shop at some point because there was over spray of clear coat on the car from being near another car that was painted that he had to buff off on the passenger side (opposite this), but the paint readings looked consistent across the car's panels.
      07-07-2020, 06:56 AM   #4
Epoustouflant
He did say the car appeared to be in a body shop at some point because there was clear over spray on the car that he had to buff off on the passenger side (opposite this) but the paint readings looked consistent across the car.
Looking at the orange peel and visible "dirt" in the clear - this has been repainted for sure.
You can tell resprays by paint thickness (our cars are 6 micros or less from OE), increased orange peel (shops can wet sand and polish, but they usually don't do edges or creases), and you may find dirt (dust specs) in the paint, suggesting a paint booth environment that wasn't OE.
      07-07-2020, 11:05 AM   #5
Ervin87
Ervin87's Avatar
You don't really need a paint depth gauge for this one. Just by looking at the handle, it's evident that it is not original paint.
      07-07-2020, 11:41 AM   #6
akkando
akkando's Avatar
5863
the paint gauge was used on the panels. my point was it doesn't appear the door etc was repainted at any point.
      07-07-2020, 12:15 PM   #7
kcdedric
kcdedric's Avatar
Drives: E90 M3
The door may not have been repainted, but that handle certainly was at some point judging by the texture of the orange peel. It's hard to tell without seeing it in person, but that could be some sort of adhesive (from tape maybe?) if it's above the paint or it could be failed clear coat if it's less thick than the surrounding paint.
Most paint gauges can't measure plastic panels. Those that can are >$2k. You could always ask your detailer what kind of gauge he uses and if he's able to give you a reading on plastic/composite parts to confirm.
Le Mans Blue '09 BMW M3 Sedan - Current
Polar Silver '04 Porsche GT3 - Gone
Persian Blue '08 Lotus Exige S240 - Gone
Space Gray/Imola '08 BMW M Coupe - Gone
      07-07-2020, 01:06 PM   #8
Dpc2u
Dpc2u's Avatar
Drives: E93 M3, E60 M5, F15 X5, E46
To answer your original question of what to do, you have basically two options.
You can have the handle redone professionally with base coat/clearcoat, or you can very carefully wet sand it to feather the edges where the clearcoat has peeled and re-clear it. You would have to be cautious not to sand through the basecoat, especially since it does appear to be a re-spray.
Option two will not give perfect results, but could buy you time by stopping the lifting and protecting the base coat.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus
      07-07-2020, 01:27 PM   #9
akkando
akkando's Avatar
5863
I talked to him he said he didn't do any plastic parts because his gauge won't work on them.
      07-07-2020, 02:05 PM   #10
JPWEraser
Drives: 2016 Corvette Z06/Z07
I've seen failed ceramic coatings look like that too.
