05-31-2019, 01:28 PM | #1 |
![]() ![]() 30
Rep 92
Drives: E91 6spd // E46 M3 LSB
Platform I'm attempting to code:
I searched high and low for the symptoms that I'm getting while trying to initiate NCS Expert software, but got a dead end. This is my first time trying to code features. The error message that I get when going through the procedure... 1)Open NCS Expert 2) Load Profile > Expertmode 3) F1 (VIN/ZCS/FA) 4) F3 (ZCS/FA f.ECU) 5) Choose CHASSIS (dialogue box and select E89) 6) Choose ECU > CAS 7) >>>>> I get the error message - - Following feature is invalid for FA: #0308 The only thing that I can think of that is causing this issue is: a) I'm using a buddy's laptop that has the software pre-installed (INPA worked perfectly, but I could not get DISv57, or NCS Experts to) b) Aftermarket Eonon headunit... is this a dealbreaker? (I think the stock one is in a box somewhere) ***UPDATE*** I did much more reading and decided to go through every prerequisite to ensure that I had NCS Expert working. After updating all daten file folders and EDIBAS files, I am now able to code successfully. That's what I get for trying to run through the standard coding tutorials with my buddy's version of NCS Expert intended for his 2001 E39. Thanks for all the help! Last edited by crimpwimp; 06-04-2019 at 11:52 PM.. Reason: FIXED |
05-31-2019, 07:16 PM | #2 |
Derbo Tuning
![]() 2992
Rep 2,664
is your COM port settings proper? is it 1ms latency?
IG:ruhrohz_m3
Journal:Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
05-31-2019, 08:23 PM | #3 |
![]() ![]() 30
Rep 92
I will double check. Thanks
(UPDATE) Yes, using COM1 and at 1ms latency timer. Last edited by crimpwimp; 05-31-2019 at 09:08 PM.. |
06-01-2019, 12:14 AM | #4 |
Derbo Tuning
![]() 2992
Rep 2,664
Do you have proper DATEN files installed?
Does NCSexpert at least see your VIN?
IG:ruhrohz_m3
06-01-2019, 01:16 AM | #5 | |
![]() ![]() 30
Rep 92
Not sure what I would have to do as far as DATEN files go. NCSexpert does recognize VIN automatically. Any recommended guides to read through to troubleshoot? Seems like I should be able to go into the airbag menu from INPA to run a diagnostic check, but I got the error pictured. Any ideas? Last edited by crimpwimp; 06-01-2019 at 04:11 AM.. Reason: Added information |
06-02-2019, 11:17 AM | #6 |
Derbo Tuning
![]() 2992
Rep 2,664
Bimmergeeks software is known to work with our cars.
https://www.bimmergeeks.net/downloads I would blow out the setup you have and run with the BimmerGeeks version.
IG:ruhrohz_m3
06-03-2019, 11:59 AM | #7 | |
![]() ![]() 30
Rep 92
Just yesterday, I was able to torrent dl newer v47.1 E89 daten files. After moving files to corresponding folders and also update EDIABAS version, I was able to get NCS Expert loaded and code out TPMS to convert to FTM system instead. Still not sure if I need to load the latest daten files, but will incrementally find out... Thanks for the help! |
06-03-2019, 04:18 PM | #8 | |
Derbo Tuning
![]() 2992
Rep 2,664
IG:ruhrohz_m3
06-04-2019, 11:48 PM | #10 |
![]() ![]() 30
Rep 92
06-08-2019, 04:00 PM | #11 | ||
Lord Scrip
![]() 1311
Rep 2,656
Drives: 2011 M3 Coupe
Tags |
bmw, coding, e91, mod, ncs expert |
