10-07-2017, 07:06 PM | #1 |
Rep 4,155
MFactory CF Drive Shaft
Thinking of picking one up for my DCT M3. Anyone have a long term review on this, in particular on NVH?
I have solid subframe bushings and stock diff bushings, car is daily driven with some trackdays. Thanks! |
10-07-2017, 07:10 PM | #2 |
Rep 12,722
its great. there is no harshness or vibration, but your car will feel more clunky and direct and you'll be more in-tune with the differential. i have solid subframe and delin diff bushings. it transforms the car from a street car into an exotic. feels fantastic to me, but it is somewhat subjective.
remember what it felt like when you got your solid subframe bushings? its like another step to that.
10-07-2017, 08:16 PM | #3 |
Rep 4,155
Thanks roastbeef! What are the noticeable benefits?
Also did you notice any loss of torque in the lower rpms? Last edited by Redd; 10-08-2017 at 03:48 AM.. |
10-08-2017, 06:14 AM | #4 |
Rep 12,722
the most noticeable benefit is the car feeling more direct, and more connected to the road. it feels like throttle response is razor sharp.
i don't track gas mileage, but it seems to be slightly better, i'm not sure about that one though. the car definitely doesn't decelerate as fast as it used to when you let off the throttle. i know it didn't lose any torque. i can't tell you the car is faster- i don't equate my faster lap times to this one item. this is a good piece in a symphony of parts working together that enhance each other and improve the feel of the car. here is the real test- if i totaled my car and began to build another one, i would buy this driveshaft again. i enjoy it that much.
Chuck's M3162.00 AWDBooSTIn90148.50 |
10-08-2017, 08:49 AM | #5 |
Rep 4,155
10-08-2017, 09:36 AM | #7 |
Rep 271
10-09-2017, 01:54 AM | #10 |
Rep 12,722
DCT.
10-09-2017, 12:20 PM | #11 | |
Rep 1,934
Also, what are your thoughts on running this CF shaft in an otherwise stock (DCT) car? TIA |
10-09-2017, 02:07 PM | #12 |
///M Powered for Life
11469
Rep 10,328
I looked on the website but it was not clear whether this reuses a stock guibo to avoid NVH
10-09-2017, 02:17 PM | #13 |
IG: @dj_dub
1803
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
I have the same exact feelings for this product as roastbeef. The difference can be felt instantly after installation. I was a skeptic but was amazed on how instant and direct the power delivery felt compared to the stock driveshaft. Definitely one of my favorite mods!
It uses the stock guibo for sure...I personally felt no increase in NVH after installation.
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
10-09-2017, 02:25 PM | #14 | |
11469
Rep 10,328
10-09-2017, 02:28 PM | #15 |
Rep 1,934
10-09-2017, 02:55 PM | #16 | |
IG: @dj_dub
1803
Rep 1,452
I did use heat wrap on my x-pipe around where the shaft meets the flange to reduce the risk of separation due to high heat. This is recommended by the manufacturer...some people do it, some people don't. I'd recommend doing it as it is a cheap and easy way to protect your investment.
buddalun679.00 |
10-09-2017, 05:54 PM | #17 | |
Rep 872
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
10-09-2017, 06:24 PM | #18 | |
Rep 1,934
http://www.m3post.com/forums/showpos...8&postcount=12 |
10-09-2017, 08:04 PM | #19 | |
Rep 872
10-09-2017, 09:04 PM | #20 | ||
Rep 12,722
you'll see a benefit of running this shaft in a stock car, just know that the subframe and differential move around a lot... like about an inch during hard driving. i don't know if there is going to be any added effect, but you're going to be putting more direct power into the differential. you'll probably be fine. Quote:
as we know, the oem shaft is easy as it bends and makes up for the clearance issue. i think i shaved about 1mm of material off the carbon shaft while i was muscling it into the pinion flange. i was carefull to push on the metal end of the shaft because this didn't stress the carbon. its possible, it just sucks. took me about 10 hours underneath the car (including sitting in the garage cursing) from start to finish.
10-09-2017, 09:09 PM | #21 | |
Rep 12,722
10-09-2017, 09:43 PM | #22 | |
Rep 1,934
Some more questions for ya: -Do you recommend solid rear subframe bushings as a logical addition to the CF propshaft? I am considering these as they add no NVH. I will likely stick to OE diff bushings. -Do you hear any sort of a "whine" especially as speed increases? Any other sounds or abnormalities as compared to the OE propshaft? -I found that the clunkiness from the DCT was largely removed with the GTS tune. Is this what you're referring to? TIA |
