12-12-2018, 08:08 AM | #1 |
Rep 2,362
Considerable oil burst from cap: overfill?
I did an oil change today with 9qts of Redline 10w60&0w40 (7:2 mix).
This time I changed the filter but did not drain from it (only from the main sump) because I thought i would be low on oil. Now the car bursts oil from the oil cap like it needs bleeding Did I overfill too much? Oil level onboard shows ever so slightly above the full mark, but I didn't know it would be this bad...
Pass me if you can.
12-12-2018, 02:42 PM | #3 |
DSC Off!
304
Rep 718
This ^
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
12-13-2018, 09:30 AM | #4 |
Rep 2,362
I left the front one alone and just drained from the main sump. It should add up nicely but apparently slight overfill.
Yeah.. it did leak before but went away after I momentarily changed to OEM 10w-60 after RB job. Guess caps are more prone to seeping with ester oils.
Pass me if you can.
12-13-2018, 09:40 AM | #5 | |
Rep 994
Why wouldn't you drain both? |
12-13-2018, 11:32 AM | #6 | |
Rep 5,506
Oil seeping is normal though with older oil caps. Just replace the cap and it'll be fine.
Auto Detailing Enthusiast!
12-13-2018, 12:08 PM | #7 |
Rep 5,483
oil under the valvecover is just being flung around by all the moving parts under there, it's not pressurized at the oil cap. Overfill won't cause this unless you put a few extra gallons in
12-13-2018, 12:33 PM | #8 |
Rep 12,726
Why in the hell would you be so careful to use two different oil weights but leave a quart or two of old oil in your car by not draining the front sump?
12-13-2018, 12:51 PM | #9 |
Rep 1,881
definitely gotta drain both sumps on the oil pan....
DrFerry6728.50 |
12-13-2018, 01:07 PM | #10 |
Rep 724
I have a sensitive valve cover, in that if one only turns the cap, one of the times on the cap won't engage with the valve cover. When this happens there can be considerable leakage. If one presses down while turning both times engage and there is no leakage.
This has occurred with both old and new caps. Every time I have to open the cap, I check after a drive to make sure it isn't leaking. |
12-13-2018, 03:25 PM | #11 | |
Rep 5,506
12-14-2018, 03:15 AM | #12 |
Rep 2,362
I thought I wouldn't have enough oil if I drained from both
Pass me if you can.
12-19-2018, 12:45 AM | #13 | ||
Lord Scrip
1813
Rep 3,013
Drives: 2011 M3 Coupe
Z K1888.50 |
12-19-2018, 01:20 AM | #14 |
Rep 2,336
That's why we have DIY threads. At least you know for next time to follow the correct procedure. Though I think no one actually lets their car sit and drain for the full hour.
12-19-2018, 10:51 AM | #15 |
mTekMods
2142
Rep 2,902
12-19-2018, 02:33 PM | #16 | |
///M Powered for Life
11483
Rep 10,329
Thank you for the link!! |
DrFerry6728.50 |
12-19-2018, 02:47 PM | #17 |
Rep 5,506
My valve cover where the cap goes on has the paint chipped. I think it is part of the reason mine is seeping oil - because the seal with the cap is not tight with the uneven mating surface. I don't really see a solution to this without replacing the valve cover.
