09-13-2018, 04:04 PM | #1 |
Rep 358
Rod Bearings for s65 in Ventura County
Anyone know of any reputable shops in the 805 that will do rod bearings in my 08 e92 M3? SSR and MRF are in the OC and I'd rather not have to do a 200 mile round trip commute if I don't have to.
much appreciated *****Update ****** Decided to go with JMP Autowerks in Canoga Park after getting my oil analyzes. Mohamad was very courteous and professional. He had the car for a week, but the work actually only took two days. Luckily they had stocked up on BE bearings and ARP bolts (due to the frequency of requests they get) so they were able to accommodate me rather quickly -- which is very fortunate for me because @97k miles it looks like I was close to losing a few bearings. See for yourself. If you are in the area I cannot recommend them enough. Last edited by Silos; 10-31-2018 at 10:47 PM.. |
09-13-2018, 04:20 PM | #2 |
Rep 743
MRF....worth the 200 mike round trip
Bimmer Barney1250.00 schnell1982345.00 |
09-13-2018, 04:22 PM | #3 |
Rep 358
09-13-2018, 05:16 PM | #5 |
Rep 358
09-13-2018, 10:19 PM | #6 |
Rep 743
Bimmer Barney1250.00 |
09-14-2018, 11:23 AM | #8 |
Rep 358
09-14-2018, 01:06 PM | #10 |
Rep 358
09-14-2018, 02:38 PM | #11 |
Rep 1,024
JMP AUTOWERKZ in Canoga park
09-14-2018, 02:50 PM | #12 |
Rep 358
Richsocal12429.00 |
09-14-2018, 04:03 PM | #13 |
Rep 1,502
@ OP I drove down the MRF from SB. It’s not a bad drive and this is a precision job. You want someone well known with a known reputation. Price is right in line with the marketplace. Also, he will swap the engine mounts. If they aren’t 100% toast by now, they’re on their way out I guarantee it.
2011.5 E90 M3 DCT ZCP Slicktop
09-14-2018, 04:43 PM | #14 |
Rep 1,024
tell them Richmond referred you and ask for Jerric
09-15-2018, 12:11 AM | #17 | |
Rep 966
Switching to a better performance brand like Torco, Motul, Redline have better protection elements. I would run a 20-50 personally. How the engine is warmed up and operated is key also. Unless you change out the connecting rods for a different spec, it'll always be a replacement item at some point. BMW finally released a bulletin few weeks back about changing out the 10-60 weight as well on the S54, S65 and S85 |
09-15-2018, 01:28 AM | #18 | |
Rep 1,502
09-15-2018, 07:17 AM | #19 |
General
63085
Rep 24,611
Malek is the man => https://www.m3post.com/forums/showthread.php?t=1039320
09-15-2018, 01:56 PM | #20 | ||
Rep 358
Will do. I spoke to a Mohamed(sp?) and he was very helpful. Quote:
+1 i'd like to see that as well. |
09-15-2018, 02:46 PM | #22 |
Rep 1,932
Drives: 2013 E92 M3
Not sure how you came up with rod bearings are not a wear item, if that were true they would not be replaceable! They do last longer then they did in the 50's and 60's but will not last forever.
