      10-16-2018, 07:38 PM   #1
Thtkidwihthem3
Drives: 2010 BMW m3 e93 le man's blu
2010 m3 e93 just put on lci lights issues
[IMG][/IMG][IMG][/IMG]I'm having an issue with the tail lights my rear inner lights are kinda confused it activated the euro fog lights on its own and not the led strip And theirs a code in my car saying that my rear passenger inner is not working properly you think coding will fix the issue?
      10-19-2018, 12:34 PM   #2
jellydoughnutt
You may have the plugs to the bulbs swapped to the wrong one. It appears that your brake lamp wires could be plugged into the revers lights. When you put it in reverse does the brake light in that one area light up? Try swapping them and see if that fixes it.
      10-19-2018, 01:26 PM   #3
jellydoughnutt
I looked at this a little more, and that spot that is lighting up is a reverse fog light, not the regular reverse lights. You should still be able to swap the plug and get your brake lamp back to normal.
      07-10-2019, 07:01 AM   #4
Pappas Fritas
Pappas Fritas's Avatar
Drives: E93 M3, Melbourne Red, 6sp
For the e93 m3, was this a direct swap in? I plan on the taillights (inner/outer), retrofit wiring harness and coding it in.
I saw that the e90 required a new trunk lid so just want to avoid any surprises. Thanks for the help!
      07-24-2019, 11:49 PM   #5
cb1
Drives: F82 LCI zcomp, e92 M3, e46 M3
Match the plug/socket. Make sure that the order of the wires matches that of the driver side. My buddy had the same problem and we noticed that 2 wires were not in the same order as the good side
