      08-28-2018, 12:11 AM   #1
pcohen15
pcohen15's Avatar
380
Drives: 2013 F10 M5, Singapore Gray
How often to strip wax?
How often should be using a wax stripper product like CG's Clean Slate in terms of number of wax applications? I live in AZ and my car is outside all the time, so I'm in the habit of waxing every three-four months for protection. After how many waxings should I use this?
Thanks!
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
      08-28-2018, 09:30 AM   #2
Montaver
Montaver's Avatar
Drives: G87 M2 & M340i LCI
No point unless you are looking to polish or correct the paint.
dparm3849.50
      08-28-2018, 09:52 AM   #3
dparm
Stop the hate, get a V8
dparm's Avatar
Bingo.
I'd suggest moving to something more resilient like a sealant that will be able to take the intense AZ sun and last longer. You can also layer those up for more durability.
Past: 2011.5 M3 sedan ZCP
      08-28-2018, 12:30 PM   #4
Banana Hammock
Beefcake
Banana Hammock's Avatar
3769
Drives: NA
As Larry from AMMO NYC would say. You want to build layers of protection. Wax is a layer of protection.
      08-30-2018, 02:18 AM   #5
pcohen15
pcohen15's Avatar
380
Thanks to all for the advice and counsel. I use a spray sealant/detailer after every wash and the shine is holding up very well. I wax every 3-4 months more for the therapy than because the shine is dulling. Occasionally, I have washed my car because it was actually dirty.
      08-30-2018, 07:46 AM   #6
dparm
dparm's Avatar
Most of those spray-on waxes and quick detail products don't last very long. They're intended for touch-ups. As I said, look at moving to sealants and similar longer-lasting products so you are spending less time waxing and more time driving.
      08-30-2018, 02:04 PM   #7
pcohen15
pcohen15's Avatar
380
Is there a sealant you like?
      09-03-2018, 03:06 PM   #8
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
I like menzerna power lok
      09-04-2018, 08:05 PM   #9
SoCalRPM
SoCalRPM's Avatar
886
Drives: e92 M3
If you're already familiar with Chem Guys, I've gotten decent results with their Jet Seal. Easy to apply. It's been a few months on my wife's black Q5 and the water still beads really nicely.
You can also check out Pan the Organizer on YouTube for some unbiased sealant reviews.
      09-04-2018, 11:25 PM   #10
pcohen15
pcohen15's Avatar
380
So here's the big question re: Jet Seal, although I'm pretty sure I know the answer: did you wax before Jet Seal, after Jet Seal, or not at all?
      09-05-2018, 01:29 AM   #11
NeverL8
NeverL8's Avatar
523
Drives: Slow
I’ve had a great results as well with chemical guys jet seal. Also paste waxes seems to last longer then spray or liquid form. If you’re not doing clay, correction and polish, I would use a sealant and then top it off with good paste wax
      09-05-2018, 10:18 AM   #12
SoCalRPM
SoCalRPM's Avatar
886
Drives: e92 M3
I've had a great results as well with chemical guys jet seal. Also paste waxes seems to last longer then spray or liquid form. If you're not doing clay, correction and polish, I would use a sealant and then top it off with good paste wax
My understanding is that you can layer a wax on top of a sealant. I don't believe you can reverse this because a sealant won't adhere to a wax. I could be wrong.
So >> use a strip wash shampoo like Clean Slate >> Clay (only if it needs it) and polish if you're able to >> then a sealant like Jet Seal >> then wax if you want to go the extra mile
      09-05-2018, 12:31 PM   #13
pcohen15
pcohen15's Avatar
380
Makes total sense. Thanks.
      09-05-2018, 01:22 PM   #14
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
Loving the new Sonax Spray and Seal. Already went through a bottle. Water beading is insane. Very easy to apply. Highly recommended.
With all the new things out, waxing is dead imo.
