02-11-2014, 09:53 AM | #1 |
Rep 343
Drives: 2008 Jet Black E90 M3
Question about "Satellite Radio Prep"
Hey guys, quick question here.... Anyone have any experience getting Satellite Radio when the spec sheet says "Satellite Radio Prep". I'm just taking a wild guess here but that sounds like it has some wiring but needs more components? Gotta have my "80's on 8" yo!
This is on an 08 E90 M3. |
02-11-2014, 10:02 AM | #2 |
Rep 1,244
Drives: 2013 F10 M5
Yes. For an 08 model vehicle, you need to purchase the satellite tuner module.
It installs in the trunk, under the floor panel. Look on the left hand side and you'll see a bundle of wires one of which has a link connector. |
02-11-2014, 10:04 AM | #3 |
Rep 343
Cool, is it just plug and play or is there some programming the dealer will have to do for it to show up in the idrive?
02-11-2014, 10:27 AM | #4 |
Rep 6,912
I believe the "satellite radio prep" costs $495 at most dealers. That's what i was recently quoted.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
02-11-2014, 10:31 AM | #5 | |
Rep 1,244
Drives: 2013 F10 M5
Plus you'll need to rearrange the fibre optic cables on the MOST block behind the rear seats. I'll dig up the installation document and post it for you. |
02-11-2014, 10:32 AM | #6 |
Rep 691
This thread should help you:
http://www.e90post.com/forums/showth...sirius+install |
02-11-2014, 11:15 AM | #7 | |
Rep 1,244
Drives: 2013 F10 M5
Models without Navigation, depending on build spec and build date, have to have the head unit swapped out for one with Sirius built-in *and* have the enabling code loaded. 2009 and earlier models only require the external tuner to be installed in the trunk and the VO updated to change the "Sat Radio Prep" VO code to the "Satellite Radio" VO code. |
02-11-2014, 11:37 AM | #8 | |
Rep 18,823
Drives: BMW
You will need a Sirius receiver, which is NLA from BMW since they started integrating them within the head units. You only choice is second hand. I have a used Sirius module pulled from our race car build if interested.
02-11-2014, 12:19 PM | #9 |
Rep 1,244
Drives: 2013 F10 M5
Here's the latest installation document for retrofitting Sirius into your M3. Contains all the parts (bracket, nuts, etc) required and explains the procedure for working with the MOST block for the fibre optics. The installation documents in the previously mentioned thread are a little dated (back in 2005-2006) but still good. I just personally prefer working with the latest documentation when doing these things.
My advice to you on working with the MOST block, **label/document all the cables in their existing positions**, while working with the MOST ring isn't hard, if you mess something up, you'll want to be able to return everything back to the way it was otherwise other components won't work properly. Overall, the process is pretty simple. Even easier if you have a competent coder local to you to perform the VO change and activate the unit. Otherwise, it's programming/recoding time at your local dealer at about 2 hours labor. |
02-11-2014, 01:12 PM | #10 |
Rep 6,912
so my 2011 x5 and 2012 M3 only need dealer coding???
02-11-2014, 01:48 PM | #11 |
Rep 343
Thanks a ton guys!
02-11-2014, 02:57 PM | #12 |
Rep 1,244
Drives: 2013 F10 M5
If they are both equipped with Navigation, yes. All 2010+ vehicles with Navigation have Sirius built into the Navigation system, it's just disabled by BMW until an activation FSC code is loaded. The navigation needs to be recoded *and* an FSC code loaded into the navigation (which you purchase from your dealer and they load into the vehicle).
If the vehicles are not equipped with Navigation, then it depends on the spec of the vehicle. You may need to swap out the radio head unit on cars without Navigation. Recoding without the FSC code will not work, the satellite functions will be visible, but completely greyed-out until the FSC code is loaded. |
02-20-2014, 10:57 PM | #13 | |
Rep 7,541
02-26-2014, 07:41 PM | #14 |
Rep 310
I am buying an 08 e93, and it has prep. Part of the deal was "satellite install at cost". It turned into them saying parts were $1300 and coding an additional $250. I think I just got the brush off!
It was my understanding that the module could be purchased used for $2-300 dollars, then the dealer install + coding ($250 sounds right), which I believe includes 1 year of your subscription. Are my numbers off here? |
02-26-2014, 08:53 PM | #15 |
Rep 6,912
Can u pm me details on cost etc?
04-28-2014, 09:05 AM | #16 | |
Rep 278
Drives: 2009 E90 M3
If so, where did you get your unit and who did the coding? Feel free to PM me if you want to go that route. Thanks, George
2009 E90 M3 in Space Gray with Fox Red Extended Leather and Carbon Leather Trim
DCT/Evolve Tune (DCT, Servo, Engine) Cold Weather/ Premium/Technology Packages 18" Apex ARC-8 wheels + Michelin Pilot Super Sports 18" Apex ARC-7 wheels + Michelin Alpin PA4 |
04-28-2014, 09:23 AM | #17 |
Rep 310
HI, yeah all set. Bought the unit here on the forums, installed it all myself, then had a local indy shop code. I did need the antenna module, although the wiring was in place there was just a blank under the shark fin.
08 E93 M3 | 06 Lotus Exige
