05-25-2020, 10:08 PM | #1 |
Rep 9
FS: Brembo 380mm Big Brake Kit/10 ROTORS/PADS
Holy Brakes Batman! Up for sale Brembo Monobloc front and rear Big Brake Kit and a whole lot more for 2008+ E90, E92 and E93 BMW M3 . Transforms the car's braking. Gives you the ultimate feeling of confidence in the brakes at any speed. It's like throwing out an anchor! These replace the single pot calipers on the stock car with 6 pot and 4 pot, that's quintuple the amount of pots! (if that matters to you) Selling all of these because unfortunately the car is no longer with me. Included with this kit are: - 6-piston Front calipers (1N1.9003A) , 4-piston Rear calipers (2P1.9013A). The calipers are black with "Brembo" in white lettering and they have just been rebuilt in February this year with new seals and dust boots. - 2 set of rotor hats, front and rear so it's easy to swap between your street and track brake pads and rotors, if you are into that. - 1 set of brand new Brembo Type 3 rotors, front and rear. The fronts just got mounted to the rotor hat and burnished in with Pagid Yellow Pads. Rears are new in box. - 2 set of used slotted front rotors and 1 set of used slotted rear rotors. These have been used on track with fantastic results. Show some heat checking marks. Still great stopping power and perfect for street and light track use. - 2 set of brand new Pagid Yellow RS29 brake pads, the front has been mounted in the caliper and burnished in. Rears are still new in box. I've been running Pagid Yellows' and Castrol SRF brake fluid with fantastic results. - 2 set of rear Hawk DTC-70 track pads that have 80% material left. - Miscellaneous used hardware for mounting rotor to hat. - Old stainless brake hose. Brembo 6 piston 380mm front brake kit - $4595 when new https://www.turnermotorsport.com/p-3...ipers/?pdk=AQI Brembo 4 piston 380mm rear brake kit - $3795 when new https://www.turnermotorsport.com/p-3...92-m3/?pdk=AgE Brembo Slotted front rotor and hardware - $1500 when new Brembo Type 3 front and rear rotors and hardware - $ 2400 Pagid Yellow RS29 front and rear brake pads - $ 900 Total when new: Over $13000 Yours now: $6500 Would prefer local (Chicagoland area) sale due to the sheer weight of the lot (~250lbs!) and potential shipping damage. Last edited by timwang6; 05-30-2020 at 11:26 PM.. |
06-04-2020, 12:08 AM | #3 |
Rep 584
If someone wants just the fronts I'll take the rears..
* 2011 M3 DCT * Built 4.4L Stroker * Gintani supercharger * Brembo GT * BBS FI * OHLINS * Nardo Grey *
06-04-2020, 06:48 PM | #4 |
Rep 4,157
Would you be keen to sell just one set - front and rear - of the rotor hats separately, since you have so many spare sets. I would like a spare set to make disc changes easier.
06-06-2020, 11:20 AM | #7 |
Rep 584
@ OP Let's make a deal!
