01-13-2018, 09:43 PM | #1 |
Rep 178
Jerez E92 M3 build/restoration
I just picked up a 2010 E92 M3 clean title, no accident (?), 2 owner, 103k, DCT, carbon roof and 100% stock minus OEM ZCP wheels that were pretty thrashed. I found it on Craigslist and made the 200 mile trip to go and get it. At first, I had just looked over it because it was obviously pretty rough from the pictures on the ad but I kept going back to it and convinced myself I wanted a project to continually improve like my last E46 M3. PO also said he replaced both throttle actuators with OEM units about 500 miles before I purchased it. Enough talk, onto the good stuff. Here's a rundown of whats wrong with it;
-Oil level was too high -TPMS failure (going to code this out) -missing passenger reflector -bent oil cooler/bumper/grille (oil cooler still perfectly functional with no leaks but I took it as an opportunity to upgrade ) -typical worn exterior trim -paint in desperate need of correction -sun fading on the CF roof -interior needs a deep clean -thrashed wheels/cheap tires Overall, the list makes it sound worse than it is. I drove back over 200 miles and it was solid. As soon as I got home I gave her a bath/decon and it was up on the quick jacks for paint correction and further inspection. I'm not sure what the previous owner hit but I believe it was just an off road excursion. He claimed to know nothing about it. Anyways, I have some big plans for her and have already started ordering a plethora of parts to include; -Apex ARC8 satin black with Michelin PSS 18x9.5 et22 18x10.5 et27 265/35 and 285/35 -oil change kit (liquimoly) -oil pan gasket -oil filter gasket -OEM transmission mounts -windshield upper/lower trim -4 new jack pads -central switch assembly (missing button) -cabin filters -BMC intake filter -OEM coolant for a flush -Turner aluminum skid plate -OEM lower grille -OEM rear badge -headlight gasket L/R -Vibratechnic motor mounts (got here in 2 days from the U.K.!) -CSF oil cooler -BE rod bearings -BE rod bolts That's it for now. I'll gradually order more and more because I'm a maniac like the rest of us. Future plans for the car include; -Ohlins R&T -Brembo 6 piston 365 fronts -Turner solid subframe bushings -Powerflex purple diff bushings -test pipes -BPM tune/GTS DCT flash -whatever else Here's some pictures I have of the progress; First fill up, FILTHY! Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr In the garage after a wash inpecting; Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Comparison after one pass with Jescar correcting compound, a MF cutting pad and Rupes polisher, not too bad. Untitled by jake ellegard, on Flickr Weathered trim; Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Hood after the first round; Untitled by jake ellegard, on Flickr Oil cooler/tray damage; Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr FILTHY engine bay; Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr O by jake ellegard, on Flickr Now for mods! O by jake ellegard, on Flickr Apex 75MM wheel studs O by jake ellegard, on Flickr Apex ARC8 Satin black w/ Michelin PSS O by jake ellegard, on Flickr Much more to come but that's all for now. Last edited by Mpower04; 01-13-2018 at 09:55 PM.. |
12
T!m3368.00 e93 jonesy58.50 Blindside_1376677.00 silverstonem3150.50 TimmyM56240.00 asif16398.50 IanMan382.50 jeff@autocouture963.00 miro229656.50 phantasticphan181.00 dimeo187516.00 DerEisbaer98.00 |
01-14-2018, 07:01 AM | #3 |
Rep 10,592
Wow. Very rough indeed, that engine bay oh my goodness.
Glad you saved that from the path that car was heading, you will give it a good life. |
01-14-2018, 09:36 AM | #4 |
Rep 1,216
Favorite build threads are reviving M cars that need attention! Great work so far I'll be following this kne
2011.5 E90 M3
LeMans Blue |
LuckiSevens227.00 |
01-14-2018, 10:07 AM | #6 |
Life is short
216
Rep 274
It's amazing how poorly some of these cars were treated. When I bought mine I thought it was in rough shape but yours is on another level. If you plan on doing a paint correction yourself that's a lot of days in your garage. Probably going to need new rotors/pads up front, new front belly pan kit, battery, spark plugs, alignment, etc.
01-14-2018, 01:09 PM | #8 |
Rep 7,046
Fantastic to see a proper bloke picking up and saving one of these great cars - awesome Warpig!
Car looked like shite when you got it, I am so looking forward to see the progress on this thread! Thanks! |
01-14-2018, 04:08 PM | #10 |
Enginerd
118
Rep 541
How does the trim get that bad?! My car has 115k and has seen a lot of 4-season abuse and spent its share of time outside but shows no cracking or wear.
Good job for giving this car the TLC it finally deserves
2008 E92 AW 6MT /// 120k orig rod bearings
01-14-2018, 09:02 PM | #13 |
Rep 178
Thank you everybody for the kind words!
Today I got some work done on the interior and put the bumper/headlights on so they could be compounded/polished. I also put the new lower grille on to see how it would fit the lower part of the bumper being slightly damaged and it fits perfectly into all tabs. I will get a Euro bumper eventually. Started by taking the front seats out and cleaning the extras the PO had left; Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Grossness on the steering wheel; Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Notice the greasy looking film... Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr After. I used Leather masters 3 part kit for the leather, cockpit premium on the plastic pieces, my commercial heated carpet extractor, steam machine and shop vac. Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Apex wheels cleaned and ready for their coating, I'll be trying Kamikaze Stance. Untitled by jake ellegard, on Flickr Hard to tell from the pictures but the seats look a lot better and don't have a sheen to them anymore. Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Untitled by jake ellegard, on Flickr Passenger side cleaned, middle and driver side not... Untitled by jake ellegard, on Flickr Next, I need to finish the exterior polishing and apply the ceramic coating. All of the parts I bought should be here by Wednesday this week so Tuesday I'll be dropping the front subframe in preparation for rod bearings and putting everything else on to make her presentable. Last edited by Mpower04; 01-14-2018 at 09:07 PM.. |
Drifter2090891.50 |
01-14-2018, 09:09 PM | #14 |
Rep 2,654
Amazing progress so far! That interior cleaned up nicely. Looking forward to seeing the ARC-8's on the car
01-15-2018, 02:21 AM | #17 |
Rep 7,046
Good first round with this task Warpig. Damn that car was dirty man. Keep that hard work up while the rest of us follow and enjoy progress!
01-15-2018, 09:01 AM | #18 |
Rep 274
Wow, the PO must have not gave a crap about this car. Can't wait to see the end result! She will be a beauty.
08 BMW E92 M3 - Silverstone II - DCT - Eisenmann - H&R - Macht Schnell
Datsun280z12.50 |
01-15-2018, 11:58 AM | #20 |
Rep 50
Drives: AW G80 6MT
So sad to see how the previous owner treated it....looks like it is making some excellent progress so far!
