      10-22-2018, 07:10 PM   #1
kimiraikkonen
Finland
275
Drives: 2008 E90 M3 6MT
Ugh.....how to get this out?
So was removing the oil separator to redo a few of the valve cover screws, when one of the Blue screws I noticed was broken and shaft still in the hole (see yellow circle).
Any suggestions on how to get this out? Am hoping I can try a left handed screw.....or maybe even loctite a peg to the bolt shaft and try to get it out. These are fairly low torque fasteners, so am hoping it's easy to dislodge.
P.S. I'm usually very good with fasteners and not overtorquing......and recently had my rod bearings done.....does the plenum come off during the RB?...or are they able to do this all from underneath the car?
      10-22-2018, 07:18 PM   #2
jdamore
jdamore's Avatar
433
Drives: 2008 e92 M3
Theres kits for extracting bolts. I've done it twice with success. In short, drill a hole down the center of the bolt, the turn in the extraction bit and the bolt turns out..
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
      10-22-2018, 07:54 PM   #3
brettcp
Drives: 2012 E93 M3
I've used these extraction kits before and they've worked great.. as long as you can get a good angle on the head of that bolt you should be able to get it out without too much hassle.
      10-22-2018, 09:28 PM   #4
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Plenum doesnt come off.
dont fish for reasons to blame the shop.
just use a pick and slowly turn the broken piece out till you can get it by hand. It's not tight.
2014 M5 6MT
      10-30-2018, 03:55 PM   #5
kimiraikkonen
Finland
275
Thanks. Just started getting a code 2738 along with a few misfires (2b41, 2b39, 2b3a, 2b3c)..........is it possible that I'm getting a vacuum leak from the oil separator that is throwing off my Manifold Pressure sensor?
      12-03-2018, 02:36 PM   #6
kimiraikkonen
Finland
275
So an update on this. I was able to get this out no problem, and instead of using bolt extractors, went instead with a Left-hand threaded drill bit.
After two turns, the sucker was already starting to get worked out of the hole and was able to grab it and hand thread it out. Big thanks to the internet for the use of Left handed drill bits.
jdamore432.50
      12-04-2018, 12:40 AM   #7
kimiraikkonen
Finland
275
Originally Posted by M3Post View Post
What is the condition of the remaining threads?
Threads were all good.
I probably should have taken another pic of the bolt fully out...but I think I was jumping for joy at that point and forgot to take the pic.
New bolt screwed in just perfectly, with no problems.
Used these left-hand bits from Irwin:
DrFerry6728.50
      11-03-2019, 07:51 PM   #8
cromagnon
cromagnon's Avatar
Drives: 2008 E92 M3
Do they sell the blue screws for the oil separator? I need to replace one and can't find any. Thx
      11-04-2019, 05:40 AM   #9
randrews15
randrews15's Avatar
Drives: 2012 E93 M3 Le Mans Blue
Go to real OEM.com and find the part on the parts diagram. From there, you can input the part number into ECS or FCP Euro and order them usually.
      11-04-2019, 10:26 AM   #10
cromagnon
cromagnon's Avatar
Drives: 2008 E92 M3
Found it. Thanks for the help.
