09-18-2020, 09:26 AM | #1 |
Rep 3
Thermostat Replacement cost
I just moved to a new town and took my '11 BMW M3 to an indy shop nearby because I was getting an "Increased Emissions" readout and the SES light popped on. They ran a diagnostic, and got a "2B59 Coolant Thermostat Monitoring" code back. The shop suggested I replace the thermostat and I agree, but the pricing they quoted me for has me concerned. They want $1238 for the whole replacement (which includes the diagnostic). This is literally the highest I've ever read of this repair being. I will be doing some of my own maintenance once I get more settled into my new place, but I just wanted to know if this strikes you all as a red flag about this shop as whole?
09-18-2020, 11:42 AM | #4 |
Rep 3
Thank you for the replies.
msan - your calculations are about what I was expecting as well. I don't know if I'm making a mistake by calculating it for the N54/55 engine versus my S65, but I don't see it being terribly more complicated or expensive. |
09-19-2020, 10:42 AM | #6 |
Rep 238
here is the link! as well as a link to a pump to transfer the coolant out with having to drain the radiator. with it i was able to do the job with the car on the ground and zero spills. i did the temperature sensor while i was in there as well. best of luck!
https://www.m3post.com/forums/showthread.php?t=928400 Hopkins 10803 FloTool Transfer Pump https://www.amazon.com/dp/B00D2QL0DU/ref=cm_sw_r_cp_api_i_6vIzFbJDEW1W2 |
Mimmer57.00 |
Tags |
e92, replacement, thermostat |
