07-18-2017, 01:23 PM | #1 |
S1N1ST3R
143
Rep 1,174
DCT E92 M3 Violent Jerking When Trying to Put in Drive
Hey guys, So I went to take my M3 out the other day, car ran and drove flawlessly. I have a 2012 E92 M3 DCT ZCP with 48k Miles.
So I got home parked the car, went to go out again about 45 min later, started the car and went to put it in reverse, and the car started jumping back and forth crazy aggressive, truthfully I was scared the trans was going to break. I quickly dropped it into neutral and it stopped. So Then I went to try putting the car into drive and same thing except this time was jerking violently forward. Shut the car off locked it . Let it sit for 5 minutes and continued to drive flawlessly. I got the car GTS Flashed about a month and a half ago. I've owned the car for 3 months and the first month and a half the car was flawless never happened. Now after the GTS flash, its been happening here or there. I wanna say about 5 or 6 times in the past month and a half. Anyone Have any thoughts ? No limp mode or codes came up on the idrive or CEL light nothing. But I have a Schwaben Diagnostic tool from ECS Tuning and got these codes. Codes: CF28: Message Error (OBD Data Engine) from the engine control, receiver DKG/EGS, Transmitter DME-DDE/ACC CF13: Message (Torque 1) Error. Receiver DKG, transmitter DME-DDE CF1C: Message (Engine Data) error from engine control, receiver DKG/EGS, transmitter DME-DDE/DSC CF15: Message (Torque 3) Error from engine control, receiver DKG/EGS transmitter DME-DDE/ACC CF14: Message (Torque 2) error from engine control receiver DKG/EGS transmitter DME-DDE/CAS
2012 E92 M3 World's Fastest N/A E9X M3 & Stock Motor Supercharged E9X M3 11.49 @ 121.54 10.38 @ 136.04 |
07-18-2017, 03:30 PM | #2 | |
S1N1ST3R
143
Rep 1,174
El Duce13.50 |
07-19-2017, 05:49 PM | #4 |
Rep 7,541
Mismatching software versions..
Car has stock engine tune?
///M Power-Belgium63316.00 |
07-19-2017, 10:42 PM | #5 | |
Rep 213
11 Space Grey, M-DCT Base M3
07-20-2017, 12:58 PM | #7 |
Rep 7,541
Flash to stock tune and see if it continues. Should not have those faults so I suspect an issue there.
07-20-2017, 01:01 PM | #8 | |
S1N1ST3R
143
Rep 1,174
What do I need to match up for both ? Is there a specific version I need to use?
07-21-2017, 02:06 PM | #10 |
S1N1ST3R
143
Rep 1,174
Interesting. I've been using him for years on all my builds and couldn't be happier to be quite honest.
07-21-2017, 03:38 PM | #11 |
Rep 1,230
He doesn't have the fastest m3 for no reason; he's not an idiot. With that said I wouldn't let him touch my car if he paid me. I'm glad everything has worked out so far in your favor and I hope it continues. Another opinion can't hurt
07-21-2017, 03:58 PM | #12 | |
Rep 965
Drives: e92 m3
jordan uses the same off the shelf files 99% of tuners out there use so it seams like you have a personal agenda here,ive had his tune on my car worked flawless used to switch back and fourth between rk and gintani when i was n/a
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
07-21-2017, 04:31 PM | #13 |
Rep 1,230
Last i checked he had the fastest f30/80 m3. No agenda, just the way things went with a few buddies of mine. It's possible he uses an off the shelf tune for the e9x, but he didn't for the e46/e39/335i. Maybe that's why he uses canned tunes now.
07-21-2017, 04:58 PM | #14 |
S1N1ST3R
143
Rep 1,174
Update: Installed a new AGM battery from the dealership, and so far so good. Haven't had any issues or any hiccups so far ! Lets see if it continues
07-21-2017, 06:24 PM | #15 | |
Rep 965
Drives: e92 m3
e92 m3 dct
07-21-2017, 06:44 PM | #16 |
Rep 1,230
I'm not going to debate you on which car was fastest. You can Google it and see there was a thread about it and he posted the slip time. The reason I have a negative opinion of his work is because his lack to make the situation right after making a mistake. Tuners make mistakes all the time, they're humans. How they go about rectifying the situation sets them apart, in my opinion. Glad the op got it figured out. If you want to talk further pm me in a respectful way and keep the clutter off the boards. Cheers
07-24-2017, 02:27 PM | #17 | |
Rep 801
What is the recommended min storage duration that would require a battery tender?
07-24-2017, 07:31 PM | #19 |
Rep 4,160
I bought this battery monitoring device that constantly let's me check my batt health via Bluetooth and a smartphone app. Gives me peace of mind.
https://www.amazon.com/CTEK-Battery-.../dp/B0188TGF6W |
DrFerry6728.50 |
07-28-2017, 10:08 AM | #20 |
S1N1ST3R
143
Rep 1,174
Update: Been about 2 weeks. Nothing has happened, everything is going smooth as butter knock on woods. Will keep you guys posted !
08-06-2017, 07:05 AM | #21 |
S1N1ST3R
143
Rep 1,174
Another update been about 3 and a half weeks and it hasnt happened once ! Hopefully the solution was a new battery !!
08-11-2017, 08:06 AM | #22 |
S1N1ST3R
143
Rep 1,174
Unfortunately the jerking had just happened again and started jumping back and forth.
