  TireRack
      10-30-2018, 12:59 PM   #1
TDW_Nero
TDW_Nero's Avatar
180
Drives: 2009 e92 M3 Space Gray
What aftermarket lug bolt options are there
As per the title, what are some options and what do you use for your oem/aftermarket wheels?
The Driveway
1691 Villa Stone Dr # 40 San Jose, CA 95125
09 E92 M3 . 06 E60 M5 . 99 2.5L Z3 . 97 E36 M3
      11-06-2018, 08:55 AM   #2
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
ECS wheel studs with black Mishimoto Aluminum lug nuts!
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      11-06-2018, 10:31 AM   #3
ebisu8
Dom
ebisu8's Avatar
Drives: E46 M3 Comp
75mm Turner Studs with Project Kics R40
      11-06-2018, 10:41 AM   #4
whats77inaname
Drives: when at all possible
+1 for Turner
      11-06-2018, 10:43 AM   #5
TDW_Nero
TDW_Nero's Avatar
180
Thanks for the replies! Looks like everyone's in favor of a stud conversion
The Driveway
      11-06-2018, 11:47 AM   #6
rdoctor
Drives: 991.1 GT3
2009 BMW e92 M3  [0.00]
LOL...A stud conversion is not necessary unless you are actually doing a lot of track time and a fair amount of wheel changes. Otherwise, it's bling. If that's what you are going after then by all means go for it. If you were asking about aftermarket lug bolts (and not lug nuts+studs) then there are a few routes. Turner has them as does Bimmerworld. Chrome or black
991.1 GT3
SOLD: e92 M3 6MT, Jet Black/Black
Dinan: Software Tune | CF Intake | Exhaust | Pulley Kit | Stage 1 Suspension | Pedals /// BBS e88 18x9.5 et19; 18x10.5 et19 on PS4 265/285 /// Lux Angel Eyes
      11-06-2018, 01:05 PM   #7
thompsac25
Stance to make her dance
thompsac25's Avatar
705
Drives: 2022 G80 M3
I wouldnt say its just for bling factor. Stud conversion is also safer I think. I had all 5 lug bolts break and blow off of my car on my e90 335i. Good thing my car was lowered, which kept the wheel inside the fender. Did some damage but I was only going 20 MPH so it could have been much worse. I presume that my lug bolts were over torqued by the shop that previously worked on my car.
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2022 G80 M3 6MT, FEMTO, BM3, KW, AWE, MAD, lots of carbon
      11-06-2018, 03:09 PM   #8
TDW_Nero
TDW_Nero's Avatar
180
I was looking into aftermarket lug bolts options because a set of lug bolts snapped off the wheel (4/5 thank jeebus). I'm currently back on oem's now
The Driveway
      11-06-2018, 03:41 PM   #9
scrammer
scrammer's Avatar
studs are also much easier to use with spacers. You don't have to get the wheel up and try and get a straight shot wheel - spacer - hub ... to put the lug through.
also saves the wheel falling and hitting off of your brake rotors
      11-06-2018, 05:54 PM   #10
slicer
slicer's Avatar
2738
Agreed - plus allows you to use different spacer sizes without having to keep track of a bunch of extended lugs. Really useful if you have multiple wheel sets and/or buy new wheels often.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
scrammer421.50
