      12-16-2018, 11:11 PM   #1
2006325i
Drives: 2011 BMW M3
This was supposed to be my DIY S65 engine rebuild post.... fail
Can a mod move this to the engine section?
A few months ago my 2011 M3 locked up during acceleration. The car would restart after a bit of cool down. To make a long story short, the pan was pulled and the #1 rod bearing was found to be spun. I decided to remove the engine and replace the damaged crank and rods.
Engine has 70,020 miles. 2011 model
Engine is on the stand.. Hard work is done
[url=https://flic.kr/p/2ce3cee]S65[
Getting excited.. Everything is smooth so far
S65
Pan off, no debris inside. Looks clean
S65
There is the offender
S65 by [url=https://www.flickr.com/photos/147133240@N07/]
Pull the bedplate and what do we have here.. Surprise!
S65 by S65 by [url=https://www.flickr.com/photos/147133240@N07/]
A shot of all of the mains
Damage to the main bearing journal, what appears to be a hairline crack.
Any advice on where to go from here?
      12-16-2018, 11:47 PM   #2
StripclubDJ
StripclubDJ's Avatar
Drives: e92 m3
You spun a rod bearing AND a main ?
Well that motor is gonna make one nice coffee table now :/
Make sure to replace the oil cooler and flush the lines for the next motor
Sorry this happened to you
IanMan384.00
      12-17-2018, 04:17 AM   #3
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
See if deansbimmer or Troyjeup can help you but he has a backlog of 50+ cars to build if not new motor.
IanMan384.00
      12-17-2018, 07:56 AM   #4
E92_TYLER
E92_TYLER's Avatar
76
Drives: 2009 E92 M3 DCT AW
2009 BMW M3  [0.00]
soooo that 03 cobra on welds tho....
Current: 09' E92 M3 DCT Alpine white / Black
Current: 13' F150 Fx4 -daily
Past: 04' E55 AMG Fbo, 03' E46 M3
99' E36 M3, 92' 240 RB26 408whp rocketbunny
03' SVT Cobra 481whp, 89' Fox 5.0 lx notch
dparm3849.50
SAMM3Y3085.00
      12-17-2018, 08:20 AM   #5
deansbimmer
deansbimmer's Avatar
3749
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
Sorry to hear of your misfortune but yes, this is what anyone should expect to see when opening an engine with a spun bearing. Main failures always crack the bearing web like that. Being able to start after a cooldown is another trade mark hint to main failure.
I touched on this in another thread with someone looking for a blown engine to rebuild for fun... It doesn't work out 90% of the time.
Your engine appears to be a main-first failure where the main failed and spun first and the resulting lack of oil to the rods caused them to spin too. Since you can't really hear a main failure there's no indication of trouble until it takes out the rod bearings and they start knocking. It can also work the other way around where the rods fail first and the heat can cause main failure unless the engine is stopped.
NoHedge67.50
      12-17-2018, 08:41 AM   #6
2006325i
Drives: 2011 BMW M3
I spoke to you by phone a few weeks ago and you called the main bearing! Could you repair this block? Or have one for sale?
      12-17-2018, 11:47 AM   #7
deansbimmer
3749
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
Yep it's unfortunately common. I don't have any blocks. Those are the most needed component for these engines. I have pallets of parts to build engines and no blocks to start with.
I've considered experimenting with repairing these but haven't been keeping the dead blocks. If you want to ship it to me I can use it towards the effort.
      12-17-2018, 12:24 PM   #8
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11480
the hairline cracks are painful, there goes the block
deansbimmer I thought the block could not be welded due to the high silica content
      12-17-2018, 01:11 PM   #9
IanMan
IanMan's Avatar
384
Drives: Alpine White M3 Sedan
JB Weld that bitch and send it. ��
You seem like a joy...... Cheers!
cjm41752.50
SAMM3Y3085.00
      12-17-2018, 02:19 PM   #10
deansbimmer
3749
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
In a perfect world that is correct. For a performance or precision build I would never advise. For an average or budget rebuild I think it would work. These blocks are around 7% silicon content. If you can have matching alloy to fill the weld puddle and don't introduce too much heat, it would be possible. Even standard 4043 rod has around 5-6% silicon but there are other component ratios like magnesium that are off. I've welded holes and other damage in these blocks before with success, just never a main saddle. I'd like to try, and then have it line bored/honed.
SYT_Shadow11479.50
      12-17-2018, 05:30 PM   #11
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
This is pretty much exactly what happened to me.
I ended up getting a complete new motor from a wrecker, that block is done.
      12-17-2018, 10:50 PM   #12
2006325i
Drives: 2011 BMW M3
The amount of carbon build up on the pistons is crazy. Is this typical of the s65? Or could it be related?
