03-10-2022, 08:32 PM | #1 |
Rep 1,237
e92 roll cages
im this has been answered many of times on here- but i cant find any concrete feedback.
does a set of wheels fit in an e92 with a half cage?
03-11-2022, 11:05 AM | #2 |
Rep 120
03-11-2022, 03:00 PM | #3 |
Rep 3,410
The JP Marketing cage offered through Bimmerworld or directly via JP can be designed to accommodate loading wheels into the rear seat from the trunk. Also it's a 6pt cage with superior anchors vs the floor mounted options.
03-11-2022, 06:41 PM | #4 |
Rep 12,728
it gets complicated with fixed back seats or sliding seats with harnesses. how do you plan on running the car?
with my e92's current setup with no rear seats/divider and fixed back front seats, its probably possible to feed two wheels in through the trunk to the rear seat area, but it would probably be a huge pain in the ass.
03-11-2022, 06:47 PM | #5 |
Rep 1,237
rear seats are out
swapped stocks for sportsters. tempted to get a basket for my roof rack and put 2 ontop and 2 in the boot to accommodate a cage.
03-11-2022, 06:49 PM | #6 |
Rep 12,728
a roof rack is a great solution. i had an aluminum basket made specifically for carrying two tires, and its well within bmw's 120lb (if i remember correctly) weight limit. i had it built while on the car to keep the curvature of the rack correct. this way, its just four bolts to take out and i can lift the rack off by myself easily. no adjusting or fuss. on and off in a few minutes.
03-11-2022, 10:23 PM | #8 |
just another M3
514
Rep 1,151
I can fit 4 295/30/18 (track set)on my e92 with an AE performance half cage. But not sure those cage are available anymore
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
