10-31-2016, 10:19 AM | #1 |
Rep 984
Deleting headlight washers for Euro bumper
I'm about to install my Euro front bumper and planning to completely delete the headlight washers. Ive searched but all the threads mention just coding them out to not spray but I'm looking to completely remove the washers and related parts. Can anyone who completely eliminated the washers give some advice on whats involved? I want to do a clean delete that can be reversed and not affect the windshield washer system. Also will i have an error code on the dash if I remove them and don't code them off? Thanks!
2004E46M36MTCBCinn 'Clubsport'
10-31-2016, 01:53 PM | #3 |
Rep 1,158
Drives: 2011 BMW M3 2020 BMW M5C
Actually it's pretty simply. There's a tube running behind the bumper secured by zip ties or hooks, don't remember. I took out most of it, then towards the end cut it off and plugged it. Weight reduction bro.
And no errors if they're not off. I had mine coded out and still on for quite a while.
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
11-01-2016, 09:13 AM | #4 |
Specialist
1309
Rep 2,706
Plug the hose at the washer reservoir tank. Remove the sprayers, nozzle, hose. Code it out for no-errors. Looks more sophisticated than it actually is.
Ta-da!
11-01-2016, 10:31 AM | #5 |
Rep 984
So there will be error codes if I remove the sprayers, nozzles, and hoses? Do they have electrical connections? Im kinda surprised that removing them would be detected and throw an error.
11-01-2016, 11:25 PM | #8 |
E90
167
Rep 821
Question: Do cars with headlight washers utilize two pumps, or one?
I see this: https://www.ecstuning.com/ES2834965/ And this: https://www.ecstuning.com/ES2580376/ Do cars with headlight washers use BOTH pumps and cars without headlight washers use only ONE pump? Or is there only one pump on both types of cars, and you just pick the appropriate one depending on which type of car you have? Thanks for the clarification! |
11-03-2016, 04:04 PM | #9 |
Rep 984
Took off my bumper today and finally got to see what the headlight washers look like. There were 2 not-good surprises:
1) the hoses are pretty thick and big, and the one coming from the pump looks to be pretty deep into the engine bay, gonna be fun trying to track it to the pump.... 2) the nozzle brackets are part of the bumper support and look like they cant be removed...only the nozzle itself. I wonder if just removing the nozzle will be enough clearance to mount my euro bumper that doesn't have headlight washer holes?
11-16-2016, 09:20 PM | #10 |
Rep 532
Why don't you just cut the holes for the headlamp washers in the new Euro bumper. I did ! Bought from IND, they painted it, they cut the holes in the bumper.
09-09-2018, 02:30 PM | #11 | |
Rep 78
09-09-2018, 02:57 PM | #12 | |
Save the manuals!
5997
Rep 6,728
09-10-2018, 02:33 PM | #13 |
Rep 5,476
I removed mine (everything but the nozzles themselves, which are light and plug the hole in my bumper) last time I had the bumper off. I was pretty surprised how much the lines weighed even with no fluid in them well in excess of 3lb. You need to take the passenger side fender liner out to get all of the hose back to the connection to the pump.
I haven't bothered to code them out yet. There's also a no-washer equipped car bottle part number, I didn't change that eaither, waiting for the dreaded cracked e90 washer bottle to happen to me again. Until then my capacity is 1/2 a liter of fluid, lol
