03-17-2014, 01:35 PM | #1 |
Rep 1,637
Wheel spacer vibration frustration (Macht Schnell content)
I'm looking for some input on a problem that has been a source of annoyance / frustration for quite some time. Wheel vibration after a front spacer install on my 2011 e92 ZCP.
Details: 1. Installed Macht Schnell 12mm spacers. (Install performed by Malek at MRF). Vibration noted on the drive home at or around 72mph. 2. Wheels balanced. Vibration continued. 3. Wheels balanced with spacer. Vibration became intermittent. Still at or around 72mph. 4. Installed Macht Schnell 15mm spacers. (Install performed by America's Tire Co.) 5. Wheels balanced with spacer. Vibration still intermittent. 6. Nail removed from tire. Wheels balanced without spacer. Vibration constant and significant. This shouldn't be that difficult. What gives? |
03-17-2014, 01:38 PM | #2 |
Rep 3,633
Have you actually measured the spacer with a micrometer? Make sure the CB is measuring 72.56. I have seen some off by only a few tenths of a MM which exacerbates at speed and results in a little shake at higher speeds.
Just remove them for now IMO |
03-17-2014, 05:34 PM | #3 |
Rep 6,734
Were the tires Balanced or Hunter Road Force Balanced? If not the latter then that would be the next thing I would try. Nobody knows how to install a spacer better than Malek so I wouldn't think the initial vibration was due to an install error. I'm also a bigger fan of Turner Motorsports spacers than Macht Schnell. Lastly, how can you balance a wheel with a spacer? That seems like a waste of time unless you are sure it's always installed on the wheel/car in the same orientation relative to the wheel.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 03-17-2014 at 05:42 PM.. |
03-17-2014, 05:53 PM | #5 | |
Rep 1,637
Re: Malek - Totally agree. He's a great guy with an immaculate shop. I wasn't insinuating error on his part whatsoever. Rather, adding further detail to the saga to show corners were not cut. You can use a 5-bolt wheel balance setup (in place of the typical center lock setup) to attach the spacer and wheel to the balancing machine. This should better account for the additional weight. This seemed like overkill and sparked my overall concern. In the past, I've simply installed spacers myself. |
03-17-2014, 05:54 PM | #6 |
Rep 1,637
03-17-2014, 06:06 PM | #7 | |
Rep 6,734
'23 X7
03-17-2014, 06:30 PM | #8 | |
Rep 1,637
I forgot to address your earlier point regarding the constant use of the spacer after this type of wheel balancing. My car only sees the street so the spacers are there to stay. That is, unless they can ride along with the shakes. |
03-17-2014, 07:10 PM | #9 |
Rep 1,463
03-17-2014, 07:12 PM | #10 |
Rep 1,637
03-17-2014, 07:15 PM | #11 |
Rep 3,633
IMO theres' no need at all to balance a wheel w/ spacer. It's just a waste. Read my post; simple to do and will rule out spacer as prob. If you had no issue before and then added spacer, it's the spacer. Meausre and make sure the CB (centerbore is correct). Keep in mind spacers will exaggerate a pre-existing issue.
03-20-2014, 08:37 PM | #12 |
Rep 4,107
grantmax, any resolution to the vibration issue? I am concerned as I will soon be adding spacers...
2021 X3 M40i
03-20-2014, 10:03 PM | #13 |
Rep 16,214
Drives: 2011 E92 M3
ive had similar issues.
i found out that my car alignment was off and made my wear on my tires wear differently and when i flipped them it was the issue of vibration. also wheels might be bent or slightly out of round which can also cause the vibration. spacers shouldnt cause a vibration only if they are not hubcentric will me an issue.
stock car
03-21-2014, 02:22 AM | #14 |
You got my money?
3170
Rep 4,655
Drives: Ice Cream Truck
Ive had MS spacers in 15/12/10 and they all vibrated. I have turner 15MM up front now and they vibrate too. My wheels are road force balanced and mine were installed with no load on my front tires.
As far as Im concerned, THEY ALL DO THIS. What you need is a new set of rims with the offset you really want. Thats my .2 cents.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
Drifter2090909.50 |
03-21-2014, 01:06 PM | #15 |
Rep 1,637
The saga continues.
I had all four wheels ROAD FORCE balanced Wednesday morning. The vibration under 45mph is gone. The vibration at or around 72mph is still there. Points of interest: 1. Wheels are not bent. Road force balancer confirmed. 2. Tires are not out of round. Road force balancer confirmed. 3. Hub is free of debris. Confirmed with my own eyes during the wheel balance. 4. I was very clear about how the wheels were to be torqued down and watched to ensure the lugs were tightened gradually and in the star pattern. Fun fact - I noticed last night that at 72mph (or so) turning the wheel slightly can stop the vibration. A quick course correction within my lane or a longer sweeping curve seems to stop the shake. Sometimes. Le sigh. |
03-21-2014, 01:34 PM | #16 |
Rep 3,633
did you measure the actual center bore of teh spacer. It takes 2 seconds and is where I would start. I have seen some off by tenths of a MM and that causes a shake at certain speeds.
03-21-2014, 01:55 PM | #17 |
General
63644
Rep 24,740
Last year a friend of mine had the same story (problem) with spacers ,the solution was .....Tighten the bolts of the wheels with the car lifted up ,the wheels(tires) may not touch the ground when tighten the bolts of the wheels !
Vibration was history !
Drifter2090909.50 |
03-21-2014, 02:31 PM | #18 | |
Rep 1,637
Tom @ EAS has me booked Monday morning if I can't get this figured out beforehand. |
03-21-2014, 02:41 PM | #19 | |
Rep 3,482
BMWCCA:518970 |
03-21-2014, 02:50 PM | #20 | |
Rep 6,913
My last set had issues around 80 MPH for a few weeks, then it seemed to work itself out and disappeared (for the most part) only vibrating once in a while after that.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
03-21-2014, 03:01 PM | #21 |
Rep 3,482
What if the spacer surfaces aren't completely level....?
BMWCCA:518970 |
03-21-2014, 06:30 PM | #22 | |
You got my money?
3170
Rep 4,655
If you search, you'll see the car has reports of slight vibration issues even STOCK at 60-80mph. The slightest imperfection can cause this vibration. So spacers only multiply the issue. The answer is a wheel with a much lower offset of you want flush with no spacer.
