BPM
      07-08-2018, 07:31 PM   #1
GSTE34
Drives: E34 turbo E90m3
Horrible cold start sound
I hear a loud rattle, crank sound. I’ve heard it could be that vanos oil check valve or timing chain guides. Some days it’s louder than others but it’s been going on for 3 days in a row now on cold start. Anyone ever experienced this?
      07-09-2018, 03:29 AM   #2
Shamza
It's typically the chain tensioner(s) but without a video no one will be able to tell you.
      07-09-2018, 03:42 AM   #3
roastbeef
roastbeef's Avatar
yea, when i wasn't daily driving my car, i would start it about every week or two and it would have a pretty good chatter for about two seconds. did the same thing before and after my bearings were replaced.
      07-09-2018, 05:54 AM   #4
///M Power-Belgium
General
///M Power-Belgium's Avatar
Belgium
63328
Drives: ///M3-E92-DCT Silverstone II
The cold start clunk (rattle) noise is normal for the S65 engine .
When *NOT DD* during cold start we can hear the loud rattle crank noise (same situation here)
Over the years I saw it fixed , but only once . It was the *Vanos-Gears* and it was a PUMA-case fixed under BMW warranty.
In this thread (with videos of the noise in #15) you can read pretty much everything about the S65 cold start clunk noise => https://www.m3post.com/forums/showthread.php?t=996069
Note: Keep in mind the S65 Vanos-Gears are not cheap !
      07-09-2018, 06:08 AM   #5
Jackntulee
Drives: E90 series
+1
      07-09-2018, 07:01 AM   #6
m235boy
Drives: M235
Same here, mine does it every single time if not driven for a few days. It's the car's way of complaining we should be driving it more lol
      07-09-2018, 08:10 AM   #7
timothy2001
timothy2001's Avatar
Drives: 2011 E92 M3 6MT ZCP
2011 M3 E92  [0.00]
Huge appreciation for the wealth of knowledge on the forum.
I really figured it was a normal sound but it's nice to see this reinforcement..
      07-09-2018, 08:33 AM   #8
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Oil pressure building in the vanos system, the rattling noise is from the sprocket.
      07-09-2018, 02:27 PM   #9
GSTE34
Thanks for the response guys but i know the rattle is normal but this is not normal i just don’t know how to upload videos here i tried when i posted and it said invalid. It’s a really loud clank before the rattle.
      07-09-2018, 02:36 PM   #10
GSTE34
I posted this video now 3 times on this forum ,and so here is it again to make this clunk noise very....very clear !
Note : This is not my car and actualy it is "the loudest clunk noise" i ever heard from our S65 engine !
Exactly the same noise as mine i found this in a comment
      07-09-2018, 03:45 PM   #11
///M Power-Belgium
General
Belgium
63328
Yep . I know , and it's normal for garage queens .
Like I said above , daily drivers don't have the noise .
PUMA-case...Read B => Fix was Vanos-Gears !
NoHedge67.50
      07-09-2018, 05:24 PM   #12
roastbeef
roastbeef's Avatar
Hmm mine sounds like rubbing some empty soup cans together for a few seconds. I don't know what that slap sound was...
      07-09-2018, 06:33 PM   #13
GSTE34
Yea I’m at 95k deff not garage queen on second engine
      07-09-2018, 06:51 PM   #14
///M Power-Belgium
General
Belgium
63328
DD ?
What happend with your first engine ?
      07-09-2018, 07:16 PM   #15
GSTE34
DD ?
It found it’s way out with out warning
      07-10-2018, 05:54 AM   #16
///M Power-Belgium
General
Belgium
63328
Was it bearing failure ?
      07-11-2018, 08:59 AM   #17
GSTE34
It was rod bolt failure. One bolt on rod #1 had backed out and ended up in. The pan with no damage. I guess i got lucky with that factory extra defect. 🤦🏻*♂️
      07-11-2018, 10:36 AM   #18
///M Power-Belgium
General
Belgium
63328
OK. I see . Thank you Sir for the information
      07-13-2018, 09:23 AM   #19
bstone801
bstone801's Avatar
Drives: Alpine e90 M3 slick stick
When my wife hears this noise every so often she always gives me the look of, is that normal? Then I just give her the look back like it is a race car, those things are expected.
      07-15-2018, 11:48 PM   #20
Scrippy
Lord Scrip
Scrippy's Avatar
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
I'm on 3rd set of RB's@160,000. I drive my car daily and love it non the less 4 years later. I have noticed I only hear vanos/valve chatter on cold startup if my car has sat for 3 days without use which is rare. It has done this since 23,000 on its first set of RB's and it would do it 3 days from now if I didn't drive it. I'm on the fence whether it's the vanos gears or simply one of the hydraulic lifters that bled out while sitting stagnant for a few days. Once oil pressure builds it goes from collapsed to filled. Noise lasts for 1-2 seconds. I love the S65.
